Author Topic: What is this SMD component?  (Read 2185 times)
Offline SaintGimpTopic starter
« on: April 13, 2017, 08:34:19 am »
Can anyone help me identify the component in the center of this photo, marked 033A?  I'm pretty sure it's blown and I'd like to replace it, but I don't know exactly what it is.  It's some sort of switching device, maybe a FET?  The top pin is the control pin.  The intended behavior seems to be that when the top pin has 3.8V, the two lower pins are not connected.  When the top pin has 1.4V, the lower left pin is connected to the lower right pin which is tied to ground.  Any ideas?  I've done Google searches every way I know how but haven't gotten any positive results yet.
« Last Edit: April 13, 2017, 08:41:39 am by SaintGimp »
Offline helius
Re: What is this SMD component?
« Reply #1 on: April 13, 2017, 08:41:37 am »
Searching for "Holtek 033A" returns useful results. HT7033A-1 is a "voltage detector".
tldr; if input is >3.3V, the output is disconnected (Hi-Z). When the input falls below 3.3V, the output is pulled to ground.
« Last Edit: April 13, 2017, 08:47:08 am by helius »
The following users thanked this post: SaintGimp
Offline TheAmmoniacal
  • Country: no
« Reply #2 on: April 13, 2017, 08:44:57 am »
I also need help identifying a part named "NMR1", all I can find is this: http://www.ic-smd.com/ssot23.asp?g=7800&s=NMR1 but it doesn't tell me much.
« Reply #3 on: April 13, 2017, 08:46:29 am »
Yes, that totally makes sense!  That's exactly what it is.  Thanks so much!  I didn't recognize the trademark which is why I couldn't find it myself.
Offline ataradov
    • Personal site
« Reply #4 on: April 13, 2017, 05:03:16 pm »
You need this https://www.westfloridacomponents.com/manufacturer-logos.html
Alex
The following users thanked this post: JJalling, SaintGimp
The following users thanked this post: jct
