Thanks. It's an IP camera from about 2012
a high speed dome PTZ superzoom, so not entirely cheap.
fzabkar : A regulator at this location is unlikely. I would more expect some single logic gate.
Also, I do not see the marking in your suggested PDF?
mikerj :
It's unlikely to be the device you suggest, because while Vss seems to be correct, I have a junctions on what on your suggestion should be NC pins.
Also, but this may be my unfamiliarity with SMD codes, but your PDF shows DG# for 3-letter code option, but a completely different 4-letter code option, and I have a 4 letter code.
