The thing i ask about TP is because in RTC datasheet its written Timing Pulses.
So TP 11 PIN RTC is Timing Pulses and TP1 and TP2 is Test points, am I right?
TP of RTC is Input or is It Output data?
Can you explain this picture, whats the text mean?
I understand. It's good that you asked again. Sometimes I don't even understand myself.
Don't mix abbreviations from the board and datasheet. They are different.
TP on the board is a Test Point.
TP in the datasheet is a Timing Pulse.
Look at some further explanations in the drawing.
The drawing is the language of engineers (my German teacher used to say that).
I will make the detailed explanation later on. When I see the full picture. Sorry.
And now we are only collecting information on RTC, you are my hands and eyes. Don't let me down!
Regarding Beeper.
Make the same measurement on its signal pin. Next one pin is +5V or GND.
