Author Topic: What more i can do?  (Read 36958 times)
Online Sorama
Re: What more i can do?
« Reply #300 on: November 24, 2024, 12:30:39 pm »
The BIOS was tested on a working board. In any case, the OP is waiting for a chip programmer. Hopefully a dump will tell us something.
And did the bios of non working board worked fine in the working board?
Obviously, yes, otherwise we wouldn't be here. ;-)
If it is that obvious, why are we measuring signals if we know the bios chipset is the culprit ?
Offline Harry_22
« Reply #301 on: November 24, 2024, 02:29:01 pm »
the only issue is that it beeps constantly (but works apart from that) , or are there other issues?
Yes the power supply is good, There is long beep no break, I even change MSDOS as well as RAMs with new working one to check if they are fault BUT still same.
Offline 222Lab_Test222Topic starter
  • Country: jp
« Reply #302 on: November 24, 2024, 11:57:38 pm »
BIOS is fine, I even put the working board BIOS to non working board, it still beep on non working one.
Online fzabkar
« Reply #303 on: November 25, 2024, 12:26:48 am »
If the problem is in a WACOM chip, then it's game over. AIUI, Harry_22 is trying to home in on the exact point where the problem occurs, presumably in the hope that it is caused by a support IC.
  • Country: jp
« Reply #304 on: November 25, 2024, 12:41:59 am »
By the way, check IC23 Pin10 and Pin11 at the same 5us/div scale. As usual, working and non-working.
ok here, i see changed signal from pasts one.
  • Country: jp
« Reply #305 on: November 25, 2024, 12:44:15 am »
Hope IC is good.
  • Country: jp
« Reply #306 on: November 25, 2024, 12:52:09 am »
To do this observe several of the CE, OE, Address or Data signals.
I see quite different CE pin here, non working board..
Offline Harry_22
« Reply #307 on: November 25, 2024, 01:27:18 am »
What is original signal should be here?
Check also all RTC input pins (please see the picture)
PS
There is some 214 kHz rudiment signal here on all the traces from non-working board.
« Last Edit: November 25, 2024, 02:11:18 am by Harry_22 »
Offline Poroit
« Reply #308 on: November 25, 2024, 02:12:54 am »
G'day All,
Should we be checking for any glitches with the power supply when the controller is first powered up?
If you read Section 2.4 as per attached it stresses the importance of power switching.
  • Country: jp
« Reply #309 on: November 25, 2024, 02:14:47 am »
this was original non working.
« Last Edit: November 25, 2024, 02:28:20 am by 222Lab_Test222 »
  • Country: jp
« Reply #310 on: November 25, 2024, 02:37:32 am »
RTC PIN11 Short to GND, CE Image
  • Country: jp
« Reply #311 on: November 25, 2024, 02:44:15 am »
All RTC input pins are same, I am sending 1 picture only.
Offline Harry_22
« Reply #312 on: November 25, 2024, 10:27:00 am »
Congratulations!
Half the work has already been done. We found a fairly thick hook that can be pulled well.
The EPROM Chip Enable signal “accumulates errors” and becomes unstable over time.
Note: The likely cause could be one of the address/data lines. The CE signal only indicates the result.
Let's move on.
G'day All,
Yes, precisely.
Probably we have some power line glitches here.
On the trace from the faulty board some other one signal with a repetition frequency 214 kHz is very noticeable.
Without changing the oscilloscope adjustments, look at the power bus IC23 Pin 14 and GND Pin 8.
Also have a look at EPROMs power line.
Next, check for ripple on electrolytic capacitors.
If you find similar signals post them here.
« Last Edit: November 25, 2024, 08:24:43 pm by Harry_22 »
  • Country: jp
« Reply #313 on: November 26, 2024, 12:01:28 am »
In working and non working board other power lines are similiar, BUT RTC IC23 VCC and GND has frequency shown up in osci...
  • Country: jp
« Reply #314 on: November 26, 2024, 12:10:35 am »
Can you clarify a bit?
Shall i check for all the capacitors?
Offline Harry_22
« Reply #315 on: November 26, 2024, 12:13:46 am »
All electrolytic capacitors. Please reduce V/Div up to 1 v/div.
Also check again IC23 pins.
Offline Harry_22
« Reply #316 on: November 26, 2024, 12:20:11 am »
Sorry, check the pins 8 and 16 IC23
« Last Edit: November 26, 2024, 12:27:06 am by Harry_22 »
  • Country: jp
« Reply #317 on: November 26, 2024, 12:54:35 am »
Yeah thats the VCC and GND pins, thats same
Offline Harry_22
« Reply #318 on: November 26, 2024, 12:57:17 am »
Please next measure A0 and Q0 EPROM lines. Set up 2.5us/div or less to see the pulses. Move start trigger line to the left to see the full picture.
Offline Poroit
« Reply #319 on: November 26, 2024, 02:08:14 am »
G'day All,
These motherboards are part of a controller for a piece of earth moving(drilling equipment) which is over 30 years old.
It has therefore probably been exposed to a wide range of ambient temperatures during its working life and even when parked up, it's probably housed in a steel sea container.
The OP does not have an ESR meter.
I suggest that the OP replaces all the capacitors on the motherboard with new, good quality ones.
Include C1 and possibly C10 if you think this could age.
BTW
What device is the WACOM Tornado T?
All the WACOM links I see relate to Visual products.
  • Country: jp
« Reply #320 on: November 26, 2024, 02:53:38 am »
BTW
I have no idea of that IC.
  • Country: jp
« Reply #321 on: November 26, 2024, 03:01:14 am »
Here,
Offline Harry_22
« Reply #322 on: November 26, 2024, 03:38:51 am »
Please print a traces from OE at the same scale.
Working ang non-working
« Last Edit: November 26, 2024, 03:41:37 am by Harry_22 »
Offline Harry_22
« Reply #323 on: November 26, 2024, 03:49:54 am »
Also please do the following.
Don't touch DIP switches but only measure and compare the voltages.
SW2 and SW4
Online fzabkar
« Reply #324 on: November 26, 2024, 03:58:08 am »
https://ww.reddit.com/r/ElectronicsRepair/comments/1g9csou/what_more_i_can_do/lx1vrat/
I think that the WACOM WE001BF northbridge/southbridge handles BIOS, memory I/O, RTC, CMOS RAM, serial/parallel ports, DIP switches, buzzer and keyboard (?). It must also handle the 100-pin (ISA?) bus.
I think that it contains everything that would be required by a standalone single-board computer, as long as the console is an A/N terminal.
The following users thanked this post: Poroit
