Or something like that. Topic starter have several boards with same issues..
Same issues board like beeping has many solutions in this board,
1. The first is CMOS Battery, When beeping if i change this CMOS battery, it stops in some cases.
2. Second is RAMs, If there is DRAM or SRAM issues, or its been placed in wrong slots it also beeps.
3. The EPROMs damaged, if they are damaged it also beeps.
4. If there is issues in CPU, like some power faults it also beeps.
In Maximum cases, the beeping is solved by this above any cases, BUT in recent boards, the problem is not solved.
Every above things is fine BUT still no work...
