222Lab_Test222
Please look at the schematic fragment from .pdf (p.14).
On the back side of the PCB, near the power connector, there are components D1, Q1.
If they match the schematic fragment, then there is a high probability that even if you short-circuit the battery to reset the CMOS, this will not be enough.
uPD 4990A can still be powered for a long time from the residual voltage from the +5V Bus.
You simply do not have enough patience.
Try to realize this and reset the CMOS not only by removing the battery and short-circuiting the contacts of the seat, but also by short-circuiting the +5V bus to GND.
(You can do this on the chip itself).
Naturally, with the equipment disconnected.
