Author Topic: What package is this? - Korg MS-20 Mini repair  (Read 1401 times)
Offline krivxTopic starter
  • Country: ie
« on: February 18, 2019, 04:04:57 pm »
I am looking at a Korg MS-20 mini synthesizer power board that has some issues.
IC1 appears to be a 3.3 linear regulator, it has 9V (input power) on one pin and 3.5V on another. 3.5V looks a little high to me, it's powering 3.3V logic. I think this part may have had it's maximum input voltage exceeded.
Forgive the blurry photo, I just had a phone at hand. Does anyone recognize the package of IC? It looks like a sot-23-6 but has 5 normal "gull-wing" legs and one additional wide leg attached to ground. I would like to replace this.
The markings are "GO3 6DB". The second character may be an O or a 0 (zero), I'm not sure.
  • Country: ie
Re: What package is this? - Korg MS-20 Mini repair
« Reply #1 on: February 18, 2019, 04:15:47 pm »
Further staring at google images results tells me this could be a Sot-89-5:
« Last Edit: February 18, 2019, 04:21:22 pm by krivx »
Offline fzabkar
« Reply #2 on: February 18, 2019, 08:22:44 pm »
http://www.smdmark.com/en-US/search/code?id=G03
R1154H036B, Ricoh, 3.6V fixed, 150mA regulator, SOT-89-5, marking G03+6xx:
http://www.mouser.com/ds/2/792/r1154h-e-844161.pdf
« Last Edit: February 18, 2019, 08:25:22 pm by fzabkar »
The following users thanked this post: krivx
  • Country: ie
« Reply #3 on: February 19, 2019, 08:26:05 am »
This look right, thank you  :-+ Surpisingly it looks like 3.59V is correct.
I double-checked the microcontroller used (H8S/2210C) and it will run at 3 - 3.6V. So this doesn't seem to be an issue.
