Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
what thing/material to prevent solder go over neighbor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: what thing/material to prevent solder go over neighbor (Read 984 times)
abdulbadii
Frequent Contributor
Country:
on:
December 08, 2021, 05:41:32 pm »
How to solder tiny, tight, narrow pinhole and PCB layout, what thing/material to prevent solder to go over neighboring pin/hole ?
Of course, means it must be little/non heat conductive to prevent draining soldering iron heat
Last Edit: December 09, 2021, 12:08:54 am by abdulbadii
Logged
coromonadalix
Super Contributor
Country:
Re: what thing/material to prevent solder go over neighbor
Reply #1 on:
December 09, 2021, 02:43:30 am »
you could use Kapton tape or what we call "peel off" its made for electronics, its a kind of semi liquid foam (heat resistant solder resistant) you mask the things you dont want to be touched .... it will dry in 15-30 mins, do the job you want to do and after you can peel it off
you have some who can be washed off ... it will desintegrate with water
Logged
abdulbadii
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
