Electronics > Repair
what thing/material to prevent solder go over neighbor
(1/1)
abdulbadii:
How to solder tiny, tight, narrow pinhole and PCB layout, what thing/material to prevent solder to go over neighboring pin/hole ?
Of course, means it must be little/non heat conductive to prevent draining soldering iron heat
coromonadalix:
you could use Kapton tape or what we call "peel off" its made for electronics, its a kind of semi liquid foam (heat resistant solder resistant) you mask the things you dont want to be touched .... it will dry in 15-30 mins, do the job you want to do and after you can peel it off
you have some who can be washed off ... it will desintegrate with water
Navigation
[0] Message Index
Go to full version
