Author Topic: Help identify an AEG diode  (Read 612 times)
Offline mairoTopic starter
« on: December 09, 2021, 12:25:29 am »
Hi all, can some one help me identify an AEG diode specs so I can get an alternative. The marking on the diode are: AEG D24N 400 U 23S7 G
Thank you
Offline fzabkar
Re: Help identify an AEG diode
« Reply #1 on: December 09, 2021, 12:46:49 am »
My searches for similar diodes would suggest that it is a 24A, 400V diode.
For example, a T24N 800 is a 24A 800V diode.
https://datasheet.datasheetarchive.com/originals/scans/Scans-007/Scans-00148833.pdf
« Last Edit: December 09, 2021, 12:57:11 am by fzabkar »
The following users thanked this post: mairo
Offline mag_therm
« Reply #2 on: December 09, 2021, 01:48:00 am »
If M6 threaded stud, probably similar to Semikron SKN20/04
N : Anode to Stud
R : Cathode to Stud
