Author Topic: What type of rs232 wiring is this?  (Read 677 times)
Offline ChrissTopic starter
« on: June 19, 2022, 10:19:53 am »
Hi!
I have to change a broken 9pin rs232 connector where the pin no 1,3 and 4 are broken, pulled out and the whole connector is crashed.
I never saw such of type of connection where pin no 1, 3 and 4 are used.
The device is a kind of "calibrator zurf" from a tractor.
What type of wiring is this?
I know the common type like gnd, rx and tx 3 wire connection.
Online Psi
Re: What type of rs232 wiring is this?
« Reply #1 on: June 19, 2022, 10:46:41 am »
It's probably not RS232 at all but some other signals using a DB9 connector.
They aren't exclusively a connector for RS232.
Offline Siwastaja
« Reply #2 on: June 19, 2022, 10:50:09 am »
There is no such thing as "rs232 connector".
It can be anything, only the user manual will tell what it is. If you can say which tractor (make/model) then maybe someone will chime in.
Online wraper
  • Country: lv
« Reply #3 on: June 19, 2022, 10:53:44 am »
It could be RS-232 with a different pinout or something entirely different. For example Sartorius precision balances were notorious for using a different RS-232 pinout to sell cables at exorbitant price.
« Reply #4 on: June 19, 2022, 11:02:50 am »
The device is not tractor specific, it is also not an oem device.
But yes, probably the main misunderstanding by me was/is that I saw the rs232 connector but probably the manufacturer use the gnd, rx,tx wires also but on a different pinout of the connector...
