Author Topic: What's the soft permanently sticky adhesive used for attaching phone backs?  (Read 1173 times)
Offline e100Topic starter
It looks and behaves like the adhesive used on double sided sticky tape, but I need a liquid version so I can apply a thin bead.
The closest I've seen so far is "off'n on craft glue" which goes on white then dries/cures to clear and behaves like the repositionable adhesive used on "post it notes".
Online coromonadalix
i use pritt products, very thin double sided tape,  i dont recall the thickness :(
https://www.grandandtoy.com/en/product/442212-0_Pritt_Easy_Stick_Double-Sided_Adhesive_Film_with_Dispenser.aspx
Online xrunner
  • hp>Agilent>Keysight>???
Yea I have the same stuff I've used to put under iPhone batteries after replacement. The tape contains adhesive "dots" that come off individually. Works well enough.
