Electronics => Repair => Topic started by: e100 on November 21, 2018, 08:24:44 am
Title: What's the soft permanently sticky adhesive used for attaching phone backs?
Post by: e100 on November 21, 2018, 08:24:44 am
It looks and behaves like the adhesive used on double sided sticky tape, but I need a liquid version so I can apply a thin bead.
The closest I've seen so far is "off'n on craft glue" which goes on white then dries/cures to clear and behaves like the repositionable adhesive used on "post it notes".
Title: Re: What's the soft permanently sticky adhesive used for attaching phone backs?
Post by: coromonadalix on November 21, 2018, 09:17:51 am
i use pritt products, very thin double sided tape,  i dont recall the thickness :(
https://www.grandandtoy.com/en/product/442212-0_Pritt_Easy_Stick_Double-Sided_Adhesive_Film_with_Dispenser.aspx (https://www.grandandtoy.com/en/product/442212-0_Pritt_Easy_Stick_Double-Sided_Adhesive_Film_with_Dispenser.aspx)
Post by: helius on November 21, 2018, 10:01:45 am
https://www.eevblog.com/forum/manufacture/about-the-glue-used-in-layer-laminated-products-and-many-modern-phonestablets/ (https://www.eevblog.com/forum/manufacture/about-the-glue-used-in-layer-laminated-products-and-many-modern-phonestablets/)
Post by: xrunner on November 21, 2018, 01:22:35 pm
Yea I have the same stuff I've used to put under iPhone batteries after replacement. The tape contains adhesive "dots" that come off individually. Works well enough.
