A couple of weeks ago my small (24") TV decided it no longer wanted to switch on. The standby LED stayed lit, and it even blinked in response to the remote, but nothing could make it actually switch on properly.
Fortunately I have another near-identical set, so it was easy to swap parts to quickly determine that the fault was on the main board. The supply rails were all OK, but for some reason it wasn't responding to signals that it should switch on. (The buttons on the TV itself, and HDMI-CEC, were ignored too).
The main board is basically two ASICs; one processor with some DRAM attached, and a power management IC. On the basis that the only possible source for either is a new board anyway, I bought a (used) replacement main PCB which came from the equivalent French model.
The new PCB powered up just fine, but of course, didn't list the UK as a supported country, so I swapped the main software Flash and the two EEPROMs off my original TV. Then it came up as a UK model, but couldn't receive any signal through the aerial. So I swapped in the tuner module from my original TV (which had the exact same part number anyway), and that didn't help either.
So, now I have one main PCB which doesn't boot, and one which boots but can't receive a signal. Neither is particularly useful as a TV.
I'm sure I probably do have the parts to make one fully working TV, but the question is, when to just draw the line and say enough is enough. My time isn't free, and although I do have the tools to swap parts from one board to another, I could easily spend a couple of days at it and still have no working TV at the end of it.
As an aside, has anyone noticed that it's all but impossible to buy a Full HD (1080 line) 24" TV now? They're all 768p, with or without "smart" fluff.
