Hi everyone, as I asked here earlier,
we've had problems with corrupted inkjet print head data in a full-color powder 3D printer. Since the printer is not covered by service contract anymore, we resorted to long (and quite expensive) component swapping. Eventually, we isolated the problem to a faulty cable that's called "festoon cable assembly" in the printer service manual. Except a replacement cable costs whopping 1200 EUR and we already exceeded our budget. So I looked if I could make a DIY copy. The "festoon cable assembly" is actually comprised of 4 different cables - earth, power delivery, stepper motor control and data for the print heads. All these cables are of high-flex type, meaning their copper cores are super-finely stranded to withstand the constant motion during printing. The problem is, the data cable is
Amphenol 191-2811-034 which isn't produced anymore. There were some leftovers in stock at Digikey, but not the 34-way variant. For my tests, I had to buy two strips of 26-way variant, then tear and glue them together to make 34 ways. That worked, but it won't probably last long due to mechanical strain in the IDC connectors.
Of course, I can't drop in any random flat cable I'd find, it must have a specific impedance, because the data rates are high. There are
SN65LVDM1677 LVDS transceivers in the printer, so theoretically, the cable should have 100 ohm. The Amphenol cable indeed has that, in "ground-signal-ground" mode. Except in the printer, LVDS pairs actually use adjacent wires, with no ground betweent them. The pair impedance is not listed in the datasheet, but I measured it with RLCG meter and got 150 ohm. I have no idea how the LVDS works properly in this situation, but... it just does. Maybe they do some trick that they interleave transmission between the pairs, so the neighboring wires temporarily act like ground?
Anyway, since the Amphenol cable isn't manufactured anymore, I looked for other sources or alternatives. The closest alternative is probably
3M 3319/34 (PVC) or
HF319/34 (polyofein). Their pair impedance is different (171 ohm, 3M calls it "balanced mode"), but I'm willing to try them. The real problem is, all vendors I could find only sell them at 100 feet (30 meters) multiples. I also tried Ebay, but I could find only listings from "dodgy" sellers who either didn't respond to my messages and/or removed the listing shortly afterwards. So my questions are:
1. Do you happen to know where I could get Amphenol 191-2811-034, 3M 3319/34 or HF319/34 in smaller quantities?
2. Alternatively, do you know about any other high-flex flat cables with required/similar impedance?
Thanks!
(I plan to write up how to make copy of the entire "festoon cable assembly" later, but I'll probably post it to 3D print-related forums, not here).
