Electronics => Repair => Topic started by: AndersJ on February 21, 2016, 11:45:25 am
Title: Where is the TEK 2245A backup battery?
Post by: AndersJ on February 21, 2016, 11:45:25 am
Thinking I might need to replace the the battery after about 28 years of use
I opened up to measure the battery voltage.
The voltage on the two diodes is 3.3 Volts, which I consider good after such a long time.
BUT, where is the battery?
I cannot find it.
Title: Re: Where is the TEK 2245A backup battery?
Post by: sync on February 21, 2016, 12:57:03 pm
On a 2246a it's on the backside of the processor board. You have to remove the board to change the battery.
Post by: AndersJ on February 22, 2016, 06:47:32 am
Found it, thank you.
The battery date code is 1988, fantastic quality.
