I've been a CNC tech for about 10 years now. I've run into a parity alarm getting thrown once or twice during that time on Fanuc machines. It was never actually the ROM. Instead it was other causes which unfortunately, I don't recall what they were. I'm thinking one had a problem on the CPU board (newer control, maybe a 31i
) and another was possibly something shorted somewhere on the machine causing a "black screen of death" and popping up with a parity error but I very well could be mistaken. Alarm messages are often misleading so you always have to take them with a grain of salt.
In any event, the ladder is written by the machine tool builder and not Fanuc. The ladder contains all the logic to interface your machines hardware with the Fanuc side. Items such as automatic tool changers, pallet changers, safety interlocks, etc. are all controlled via the ladder so it will be very specific to what hardware options your machine has. In case you do have bad ROM(s), I would get in touch with Hardinge with your model and serial # and see if they can e-mail you a copy of the ladder for your machine. We've had mixed luck with manufacturers being able to provide data like ladders and parameters on machines that old and even one that was only a couple of years old.
If they are unable to provide it, I would ask over at Practical Machinst (
www.practicalmachinist.com/) and CNC Zone (
www.cnczone.com/) if anybody has the same machine that would be kind enough to send you a copy of their ladder. If there are differences in hardware between the machines you may still need a copy of fladder (big $$$ to purchase from Fanuc) to edit the ladder to make things work. If the ladder you get has extra hardware it would be possible to change the ladder to get it to run on your machine. If on the other hand your machine has hardware that the ladder doesn't support, adding support for it is probably not feasible. I would also suggest that you post your issue on both those sites also as there are many folks much more knowledgeable than myself with Fanuc control issues.
