Author Topic: Where to buy large binding posts?  (Read 3514 times)
Offline kelchmTopic starter
« on: January 26, 2018, 09:04:53 pm »
I'm looking for a source to buy large binding posts like the ones in the attached photos. I've tried searching the usual sources but haven't yet turned anything up.
Offline ez24
  • L.D.A.
Re: Where to buy large binding posts?
« Reply #1 on: January 27, 2018, 01:36:05 am »
I am curious also.  But I suggest you list the sources just in case.
Offline sleemanj
  • Professional tightwad.
« Reply #2 on: January 27, 2018, 01:53:26 am »
Search Ali by the bolt size, that looks about 10mm, if you search aliexpress (for exampl) for 10mm binding post or M10 binding post you will find a few.
These look pretty close (no relation or recommendation, just the first result in a search)
« Last Edit: January 27, 2018, 01:54:59 am by sleemanj »
Offline Nusa
« Reply #3 on: January 27, 2018, 02:33:57 am »
You can also search by current. Try 100A or 200A binding posts for something in that size range.
Offline ez24
  • L.D.A.
« Reply #4 on: January 27, 2018, 02:49:40 am »
I am looking for something but I do not know any names.   I believe it is a small post used years ago to connect an alligator clip to it.  Sorta has a T shape to it, the T at the top.  I have spent hours on Aliexpress looking for it.  Any ideas?  Just the name would help.
Anyway this looks like it is about 4 inches long
https://www.aliexpress.com/item/10mm-Bigger-binding-post-terminal-connector/858266759.html
Offline Nusa
« Reply #5 on: January 27, 2018, 03:08:47 am »
Possibly, ez, but I'm always suspicious of listings with no indication of which measurement is 10mm.
This one, however, looks like a fair match for what the original poster is asking for:
https://www.aliexpress.com/item/M10-Gold-plated-copper-100A-Large-Current-jumbo-Terminals-for-inverter-Voltage-regulator-electric-welding-machine2pcs/32725895508.html
Offline phil from seattle
« Reply #6 on: January 27, 2018, 03:17:24 am »
Offline sleemanj
« Reply #7 on: January 27, 2018, 03:36:34 am »
While I don't think I've seen any shaped like that I expect you might be thinking of some type of a turret, or a test point.
This is a typical turret
This is a typical test point
Offline Richard Crowley
  • KJ7YLK
« Reply #8 on: January 27, 2018, 03:36:49 am »
Not clear whether you are asking about a round profile, or a flat, 2D "T shape"?
If you are talking about a round post, the thing that came to mind is a turret terminal:
Like this Keystone 1502-2
http://www.keyelco.com/product.cfm/product_id/3294
The following users thanked this post: ez24
Offline MarkF
« Reply #9 on: January 27, 2018, 04:10:29 am »
These from Digikey look like ones I have and what you want:
Binding Post Connector Standard Hex Black Nickel
They also have the cooresponding red ones.
« Last Edit: January 27, 2018, 04:17:46 am by MarkF »
« Reply #10 on: January 31, 2018, 05:21:48 pm »
Thanks, this was the thing I was missing in my searches. I turned up these, which appear to be nearly identical to the ones I am trying to replace.
« Reply #11 on: February 01, 2018, 10:35:50 pm »
These are looking very similar to the ones you have:
They can be found here:
https://www.ebay.com/itm/111289286260
