I found some mentions of them, so they do exist, but I didn’t search for vendors.
What certainly seems to be a lot more common is 112560, i.e. 5mm longer. OP, would that potentially work? If you’ve got those 5mm to spare, then the slightly longer version would be a simple replacement.
If not, you could sacrifice a bit of battery life and install a slightly smaller battery, like the common 102050.
