Author Topic: Where to find a replacement 35 Mohm NTC / thermistor?  (Read 674 times)
Offline TheAmmoniacalTopic starter
  • Country: no
« on: May 19, 2020, 08:01:54 am »
I'm trying to fix a PCR machine / thermocycler, the only fault I can find with it is a broken temperature sensor in the heater block (it reads open / OL ).
The other sensor in the heatblock seems to work and reads 35 Mohm at room temperature and drops to about 25.5 Mohm at 45 C.
Problem is I can't seem to find a comparable part / replacement anywhere? Anyone know?
Offline ace1903
  • Country: mk
Re: Where to find a replacement 35 Mohm NTC / thermistor?
« Reply #1 on: May 19, 2020, 09:30:52 am »
35Mhom is quite an unusual value. I would guess that is sensor misidentification. That ohmic range is probably an intrinsic silicon sensor.
Possibly but only if cycling is at extreme temperature ranges.
But PCR is at ~room temperatures I guess.
Give us more info about equipment, pictures, how sensor looks like.
If electronic is simple I think it is 1N4148 used as sensor and 35Mhohm is because of the wrong polarisation.
The following users thanked this post: TheAmmoniacal
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: May 19, 2020, 09:35:32 am »
Try diode test rather than ohm test.
Seven Transistor Labs, LLC
  • Country: no
« Reply #3 on: May 19, 2020, 09:59:30 am »
That would explain a lot..
In diode mode both reads 2.6 V in one direction at room temperature. Neither appears to be faulty then.. Any idea how the temperature sensing works here?
Online Kleinstein
« Reply #4 on: May 19, 2020, 04:34:30 pm »
The forward voltage of a diode makes a reasonable temperature sensor: relatively low noise, low power and still low resistance, cheap and linear from some -150 C to +150 C with some -2 mV/K for silicon (more accurate 1.12 V extrapolated to 0 K, so that a single point adjustment can be be sufficient).
The 2.6 V may be several diodes in series for an average temperature - this would be still a little unusual.
Offline fzabkar
