Author Topic: where to get these battery packs?  (Read 554 times)
Offline OgitekTopic starter
« on: January 19, 2024, 08:42:49 am »
where to buy batteries in series?
« Last Edit: January 20, 2024, 05:15:00 am by Ogitek »
Offline wasedadoc
Re: where to get these battery packs?
« Reply #1 on: January 19, 2024, 03:48:14 pm »
You could make your own packs by purchasing 12 tagged NiMH cells and reusing the wires from the original packs.  Get cells that are at least 2200mAh as the charging circuit probably trickle charged the original NiCd cells.  NiMH cells should be trickle charged at a lower percentage of the capacity rating than NiCd cells.
Offline tooki
« Reply #2 on: January 20, 2024, 09:16:28 am »
Editing the original post to remove all contact after someone has replied is hella rude.
The following users thanked this post: dino7
