Hi, I am a n00b. I have several old Porter Cable 19.2 volt power tools that still work great. I rebuilt four batteries a couple years ago with 3800mAh packs, which was somewhat expensive, but since then both of my Porter Cable chargers (model 8624) have stopped working. One of them had a couple questionable solder joints, so I re-did all joints on both units but it didn't help either of them.
Upon being plugged into mains power (USA), a properly functioning unit should make a brief audible relay click along with the green LED lighting up, and then both the relay and the LED should deactivate. After that, the unit should wait for a battery to be inserted and when one is sensed it should make another relay click sound and begin testing & charging the battery.
Unit A doesn't show any signs of life when plugged in, no click, no LED. When I attach a battery, nothing happens.
I put the multi-meter on this unit and found 120vac at various points, and 10-20vdc at other points, but I get lost diagnosing it after that.
Unit B sometimes shows signs of life when plugged in... maybe 1 out of 15 times I plug it into mains power, it'll click the relay for a split second and maybe the LED might flash too. In these cases, nothing further happens when connecting a battery.
Maybe 1 out of 30 times it WILL actually start charging a battery, but if it gets that far it usually won't actually complete a charge cycle...I come back and the unit is dead to the world again and the battery might or might not have gotten a partial charge.
Maybe 1 out of 60 times, it will fully charge a battery without going into a coma. The last time I got it to charge one battery, it also charged the other three consecutively without any problems.
I could not find schematics for this charger, and both units (same model 8624) are different inside anyway... Unit B has a green PCB, while Unit A is beige and has older looking components laid out differently.
I sure would like to repair both of these units, because they are scarce and way overpriced on ebay ($50-70 US, even if UN-tested). I doubt there is anything seriously wrong with either of mine - probably just bad capacitors, but the caps are not leaking/bulging and I don't know how to diagnose anything further. If I had schematics, I would at least know what does what and have a rough idea of where to start looking, but I don't know enough about electronics to just look at a PCB and know how it works.
Would anyone be willing to help me save these units, so I can charge my perfectly good batteries so they don't go to waste? I would want to fix Unit B first since it sometimes actually works.
Thanks in advance!
