Author Topic: Which rotary encoder is this ?  (Read 893 times)
Offline KingpinTopic starter
« on: February 27, 2021, 12:31:24 pm »
Hello,
I'm looking for a replacement encoder but can't find the right part number.
Does anyone know which type this is:
Thanks
Re: Which rotary encoder is this ?
« Reply #1 on: February 28, 2021, 10:49:27 am »
Belongs to a GeneralMusic WK4 keyboard.
Found a partnr 110254
Offline Twoflower
« Reply #2 on: February 28, 2021, 11:00:58 am »
As they are 'only' behave like two switches that opens close in a specific manner you probably don't need the exact part. As the decoder obviously was connected via wires helps a lot. That means only the the number of detents, the axis type/length and the mounting option is important.
Eventually you'll find a replacement here: https://tech.alpsalpine.com/prod/e/html/encoder/incremental/ec12e/ec12e_list.html . They are all intended for PCB mounting, but some have a thread as well.
« Reply #3 on: February 28, 2021, 11:30:09 am »
Thanks.
Found out is has 24 detents and a schematic:
Offline Twoflower
« Reply #4 on: February 28, 2021, 11:47:41 am »
Purely guessing on the dimensions here, this one looks like a matching candidate: https://tech.alpsalpine.com/prod/e/html/encoder/incremental/ec12e/ec12e2420801.html
But you should go through the specifications if that one will do for you. For example the original part has a pin to prevent rotation of the encoder itself. The Alps does not have that, but a flatted thread. So you might need a special washer that holds into the flattened thread and provide the pin that goes into the front panel.
« Reply #5 on: February 28, 2021, 01:07:21 pm »
Thanks !
I think this is the direction I'm looking for.
Online tunk
  • Country: no
« Reply #6 on: February 28, 2021, 01:26:54 pm »
Why not take it apart - you might be able to fix it.
« Reply #7 on: February 28, 2021, 02:34:38 pm »
That's an option. But i never did.
