Try holding down the Spanner icon (if touch) or any mode button the panel.
When i was working with medical equipment for Phillips most of our gear had a button on the main pcb for maintenance, sometime labeled Interlock-defeat , sometimes just MAINT and on all the larger tech it was unlabeled and in machines like the MRI systems was even behind a screw panel and still required a code on the computer of HMI to continue. It was all part of the steps we took to ensure our safety.
there was some tech i repaired like de-fibs which had a power on sequence you did to enable maintenance mode, it had to be on Main input (charging) , paddles had to be unplugged and a cap fitted and when you power up you also held the discharge safe button which dis-armed the device until a code was entered with the 4 way key (up =1, right 2 etc)
a quick look at other devices from the same maker shows they have a hidden screen which is displayed by holding next for 2 or more seconds. when i dont know as there is no pictures.
darkspr1te
