Actually, this is a "possibly needs repair" issue. The story:
I have a GAPA whole house air cleaner, attached to my HVAC system. To be precise, it has the Bryant badge (but is identical to the Carrier unit), full product is GAPAAXBB1625.
Last summer, we had a slight flood (less than an inch of water) in the basement and the cardboard filter was dampened/ruined. When discovered, the HVAC system was still running, but the light on the air cleaner front panel was out. I turned everything off, cleaned everything up and dried everything. When reassembled, the HVAC system ran (no surprise, really) but, much to my disappointment, the light on the air cleaner stayed off. I pulled the air cleaner main unit again and decided to take a peak in the KIT62000 power supply. It is closed with security TORX but that was no problem, I have a full set. Anyway, there was no smell and nothing visually to indicate any problem. Everything is lightly potted. No apparent fuse. Seeing nothing to do and needing air conditioning more than air cleaning, I put everything together again, turned it on and "lo and behold" the light came on.
So, why do I think it might not be working anyway? We've had the cleaner for several years and I clean it and replace the filter every six months. I've just finished doing it again and I noticed that the distinctive pattern of dirt on the filter, that has always been there before and seems to be related to the metal "points" on the "rails" in the unit, was missing. The dirt was simply evenly distributed across the filter.
So I'm wondering how to test it. I'm considering running a wire into the unit and testing it in place. Some of the parts inside indicated that they were rated for 22KV. My "best" meter has a 4.1 digit DC volt range, so I can't test it directly.
Finally, in addition to the service call, I'm reliably informed that a replacement power unit (it's non-repairable) is a couple of thousand dollars US.
