Author Topic: whre to find pcb repair kit?  (Read 7541 times)
Offline ddavideborTopic starter
    • Sideband
« on: June 22, 2013, 11:03:41 pm »
hi guys
i've seen on the paceworldwide video this interesting kit for repair pcb http://www.paceworldwide.com/products/support-products/nonthermobond-cirkits/cirkit-basic-version-
do you know where i can buy something similar (and maiby cheaper)
Currently working on the future of Altium library management https://getsideband.com/
Need Altium Designer Libraries? Check out https://getsideband.com/libraries (35k symbols, 34K footprints)
Offline don.r
Re: whre to find pcb repair kit?
« Reply #1 on: June 23, 2013, 01:57:12 am »
hi guys
Really depends on the damage you want to repair but I have had luck with window defogger repair kits from auto stores which are basically a liquid conductor that you paint on.
Offline vk6zgo
« Reply #2 on: June 23, 2013, 03:13:24 am »
I've used CirKit repair kits & they are very useful.
I found that the eyelet setting tools don't always make a good contact on the track.
If you use the end of a centre punch,or similar to finish the eyelet off,you can do a very nice job.
They are too damn expensive,though!
Way back in the day,they were a lot cheaper comparatively speaking,but I suppose,with a smaller market they have to make more profit on each kit.
Offline nanofrog
« Reply #3 on: June 23, 2013, 07:48:20 pm »
Are the eyelets supposed to make a gas tight weld or just physical contact + solder between what remains of the original exposed copper on the PCB and underside of the eyelet?
Offline vk6zgo
« Reply #4 on: June 24, 2013, 02:18:06 am »
Tight physical contact---I find that if the peened over bit isn't "snug" to the track,it is hard to get a satisfactory solder joint.
Offline blackdog
  • Please stop pushing bullshit...
« Reply #5 on: June 24, 2013, 07:16:08 am »
Hi ddavidebor,
You can try to buy this "Asus Repair Kit"   :-DD
Kind regarts,
Blackdog
Necessity is not an established fact, but an interpretation.
    • Sideband
« Reply #6 on: June 24, 2013, 01:14:27 pm »
Mmh...
« Reply #7 on: June 24, 2013, 05:47:06 pm »
My PCB repair kit was 5 tubes of assorted superglue, from thin to thicker than molasses, and a roll of kynar solid core wire. As well a set of needle files and a desk lamp and a few magnifying lenses to see the close up, along with some dental picks. Worked to fix 4 layer boards that had a very old copper trace that would lift even if you looked too hard at it, only thing keeping some boards together was the Mesoupolet K conformal coating that they were dipped in. I have a cheap hobby drill and a large collection of small bits as well to make new holes to anchor the wire to the board.
Offline vk6zgo
« Reply #8 on: June 25, 2013, 06:51:01 am »
I've pretty much done the same,as most of the time I couldn't get my hands on the Cirkit stuff!
One kit for about 5 different departments!
I used them when I could,though,& they are very useful.
Sometimes,I peeled tracks off old PCBs,cleaned them & reattached them to the board I was repairing.
It's amazing what you do fix over the years!
A switchmode supply in a picture monitor blew up in a big way,burning 25mm holes where some of the rectifiers lived.(two diodes in one pack).
It looked like a candidate for the bin,but I decided to try,anyway.
I reamed out the holes,epoxied in some small circular PCBs that were for some forgotten project,modified the tracks,connected  the required bits,replaced other cooked parts,put it together & away it went!
« Reply #9 on: June 25, 2013, 04:22:47 pm »
There was one board where the repair was to order a new one, complete. You are not going to repair a board that is a solid black charred block with pieces of transformer vaguely visible sticking out of the foamed up remains of the epoxy encapsulant. The replacements were a 8 figure cost........... Each.  They came in the post in an ordinary parcel. Took about 2 days per unit to remove the old ones and clean up the case enough to put a new one in as well.
Offline soldertools
    • PCB Repair Tools and Materials @soldertools.net
« Reply #10 on: May 10, 2016, 01:05:55 pm »
BEST PCB repair kits and materials give you the tools you need for fast repair and modification of lands, traces, contact fingers, SMT pads, plated hole connections and PCB base board material. These materials, packaged together and designed by one of the premier PCB repair companies, BEST Inc. allow you to meet original PCB quality standards. BEST Through-hole repair kits are designed by artisans who have been repairing circuit boards for many years, therefore the right tools have been included in this general through-hole repair kit. Plated Hole Repair Kit includes all the tools and materials you’ll need to repair damaged plated through holes in circuit boards. Get more information visit our site:- www.soldertools.net Contact Us: 3603 Edison Place Rolling Meadows IL 60008 USA Phone: 8477979250 Fax 847-797-9255
BEST Inc offer PCB repair tool kits and materials that helps you in fast repair and modification of lands, traces, contact fingers, SMT pads, plated hole connections and PCB base board material.
