Will also add replace all those 160V waxed paper foil capacitors, they all tend to either get very leaky, or just go intermittent. Replace all those red label Siemens capacitors, after a half century past their warranty they will be well dried out, same for the blue Siemens ones. Insulate all the places where transistors touch cases with component leads, case is invariably connected to collector.
Polystyrene capacitors are very temperature sensitive, and also very sensitive to common cleaning solvents, alcohol will destroy them, along with any other solvent. If replacing you can use a polypropylene film one, or a NPO ceramic capacitor, as both are stable enough in this application, and can go down to 47pf and 510pf in a sensible size case.
