Author Topic: Why every new horizontal output transistor is blowing in a LG CRT television?  (Read 6958 times)
Offline DhanushkaTopic starter
  • Country: lk
Dear all,
I replaced leaked old fly back transformer with new one and also horizontal output transistor of my LG 21" flatron CRT TV. But it was blown when I powered up. Without H-OUT transistor, 75 W and 60 W light bulbs are parallel at B+ and ground B+ has 112.5 V and big capacitor has about 320 V. Horizontal drive transformer has not short between primary and secondary. I replaced HOT again and turn on the TV without yoke and degousing coil the TV was on with series 75W light bulb. But, When I connected only yoke and powered on, again HOUT was blown though there is the series bulb. What may be the problem?
Thanks
« Last Edit: October 18, 2019, 08:55:50 am by Dhanushka »
Online wraper
  • Country: lv
But, larges capacitor is little swelled. But capacitance is 206 uF
Capacitance measurement is of little use. Capacitance may measure fine but ESR can be 100 times higher than initial value.
The following users thanked this post: Dhanushka
Offline james_s
If a capacitor is swollen that's the obvious place to start. That's a clear indication that it is in bad shape.
Offline PKTKS
  • Country: br
Apart from individual component health..
You should check the Horizontal driver wave form input.
Remove the transistor and fit a dummy load suited to have
at least the wave form... this wave is crafted to drive
a very specific load so you should not have anything
far from the manual specs. (right in the coupling transformer
which feeds the driver)
Also you must issue the proper CHASSI  for any reasonable
guess - there have been so many changes in that section
across the years which make even guessing speculation.
The wave is also usually damped with some  sort of FR diode.
Paul
Offline fzabkar
In addition to the capacitor, another common cause of failure is dry solder joints at the horizontal drive transformer. I would reflow all the pins.
One more thing is the possibility of Chinese fakes (I have been stung). Did you purchase your LOP transistor from a reputable source? Typically with fakes, the set will run for several minutes and then fail. You should run it for a short time and test the temperature of the transistor. It should not run hot.
  • Country: lk
This was solved after replacing exactly same transistor. Previous transistors may be fake ones.
Thanks for everyone who have helped for me. Specially thanks fzabkar.
Offline PKTKS
  • Country: br
Unfortunately this problem have increased over the
past decades with prices not dropping for originals
and new brands offering clones of several wide
used semi.
I generally buy a more wide supply for having spare
parts to change adhoc... just in case the match is
really the semi quality.
Pesky problem
Paul
Offline james_s
Nobody is making CRTs anymore so it's likely that nobody is making the relatively specialized transistors used in horizontal scan circuits for CRTs. Certainly the output transistors are not the mass market parts they once were.
