A very strange thing that I've never come across before.
Accidentally I think I found one fault on one board just by holding it in hands, turning around and closely inspecting (because I need to work out the rat nest across the components).
In doing this, I noticed a very light but distinct clicking (metallic) sounds when turning the board, definitely because of the flexing of it due to its weight (this is when it's held in only one hand), and due to the (very light) forces imposed on it by my hands. Because there are no moving parts on the entirely board, there must be a crack somewhere, either in a trace or a component, or somewhere else.
Strange enough, having done whatever I can do (including with a magnifying lens), closely combing through every square mm of each side of the board, I just cannot find where exactly the crack is. By holding one part each time and repeat, I think I located where the problem probably sits --- inside a resistor. There is no sound when it's lightly pressed (or touched) when turning. My explanation is that the sound is either eliminated by pressing it (causing the gap to close) or the sound it largely dampened. That said I'm still unable to observe any relative movement between parts of it (such as between a pin and its body) when bending the board slightly, nothing whatsoever. So I cannot be 100% sure.
What else did I do with it? Tried to measure the resistance of it with too alligator clips on its two ends --- the reading is correct: 6.8k. What's more interesting is that, after doing this, I cannot get the same sound again!
The only explanation I can come up with is: the use of alligator clips on its two ends -- due to the weight of the clips and the wires --- its two ends have been bent slightly closing whatever gap there existed before.
Because this fault is so evasive, if I take it off, by applying heat and force, it's very likely it looks perfectly good.
Not in a haste to take it off yet because first I'm still not very sure about this and second, there is much more test and investigation that need to be done. Even if it's faulty, there are probably more problems somewhere because its role here is still quite peripheral --- it's related to another solenoid not related to the motor.
In the photo, it's the smaller resistor starting with a blue band at LHS of a transistor.
