Author Topic: Wifi Camera stop working  (Read 613 times)
Offline sdancer75Topic starter
  • Country: gr
« on: September 02, 2020, 09:31:39 am »
I used for about 1.5 year a Security Robotic Eye camera from  https://cvmore.com/en/smart-security/. It seems that it has the same board you can find in DOG-1W-V5 from Shenzhen CYLAN Technology https://fccid.io/2ADHE-DOG-1W-V5/Internal-Photos/Internal-Photos-4017528.
The camera is not working and it seems that the board problem, it burned also the USB charger.
I noticed that the speaker is getting too hot as well as the IC8310 which at the 1st glance searching on the internet is a "16 steady-state current LED driver" but its probably wrong since the output of the speaker is getting out from this IC. So I think its an older model of ES8311 IC which is a Low Power Mono Audio CODEC (I suppose they are compatible)
https://pdf1.alldatasheet.com/datasheet-pdf/view/1132836/EVEREST/ES8311.html.
Due to the small package size (QFP) I can not test the input analog and digital  voltages pins (DVDD, PVDD and AVDD). How to handle this situation?
Regards,
***Edit 08/09/2020
Everest Semiconductors provided me the original datasheet of the ES8310 IC. Because I didn't find anyway in the web, I attach it here for anyone that is interesting about.
« Last Edit: September 08, 2020, 08:31:31 am by sdancer75 »
