Hi, hummerjanne. I see that you have a low number of post. I take it that you are a new member. Welcome.
I am posting to let you know that this forum, like many others, has it own set of unwritten rules. And, that the way you have posted your question is not likely to get any replies, at all.
You need to give us a great deal of information...
- The make/model/year of the screen and what is it used for? Computer display, TV, etc?
- Though the motherboard is defective, please provide us with its schematic, if you can find it. Well, all of the schematics... The power supply, etc. The service manual for the screen would be very helpful, as well.
- Post lots of pictures of the inside and outside of the display. Particularly of any damaged areas.
- What testing have you already tried, if any, and the results.
- What do you intend to use the screen for? Do you want to repair it, or salvage its parts? Testing for different uses will be very different.
- What are your electronics skills, level of expertise and tools available to you?
This is just a rough start to the information that you will need to research, yourself, and provide to us, in order to get started. Be prepared to do much more research and learning.
We are excited to help you and look forward to hearing from you very soon.
