Hi all,
I am facing a fault on a CRT board (KME MB22) but hard to troubleshoot as it's not available the electric diagram. As you can see below in the video, from time to time, the horizontal driver shuts down for a while.
I already tried to move horizontal inductor trimmer, tried to check the solder jonts and replaced the electrolytic caps. Power supply voltages seem OK, as well.
There is a red wire starting from the PCB and labeled as "A1" towards the pin_base of the CRT on which I found high voltage (about 450-500Vdc) and everytime the defect appears it goes down as in this video
https://youtu.be/To5Zq-NKuFYWhat do you think?
Thank you
