Author Topic: Wire for AA batteries  (Read 496 times)
Offline laispaisTopic starter
  • Country: no
« on: May 26, 2023, 11:31:50 am »
​Im going to relocate the batteries in the xbox controller to where the rumble motors used to be. So I need some wire to connect the batteries to the circuit board. How thick wire should I use?
Offline Psi
Re: Wire for AA batteries
« Reply #1 on: May 26, 2023, 11:36:56 am »
Just about any wire will work fine for that, if you need a number use 24 AWG.
That is good for 3.5A in this application, and you're never going to be pulling that out of AA's
Use stranded core (not solid core).
« Last Edit: May 26, 2023, 11:39:20 am by Psi »
