Author Topic: WORX drill repair - switch  (Read 1963 times)
Offline mintsoftTopic starter
« on: July 26, 2020, 05:22:41 pm »
Hey,
I've just been given a WORX drill driver to repair as it's flashing when you press the trigger. Quick multimetre test shows that the 4/5 of the switches contacts are all shorted together. I was trying to get a replacement however the markings on it are:
DLK-2036R and JIABEN (I assume this is these guys: http://www.jiaben.com/en/index.asp ). I can't find that part anywhere at all, I'm wondering if this is maybe a standardised switch and someone might know of an alternative?
Pic attached
Thanks
Rob
Online coromonadalix
Re: WORX drill repair - switch
« Reply #1 on: July 27, 2020, 06:05:36 am »
since you have 3 wires  red black and yellow going out of it,    the switch is not a simple switch, i has some electronics in it
apparently this one is a substitute
https://www.ebay.com/itm/1pc-USED-JIABEN-DLK-2036R-20A-36VDC-Trigger-Switch-VA51-CH-/184322919785
« Last Edit: July 27, 2020, 06:08:37 am by coromonadalix »
