Not really.
I found the weak point at lower left corner of controller. With some pressure, the system booted stable.
So I tried to resolder the Controller chip, with the hope to fix broken solder joint. But the coating destroid the rest of connections. Now I have the PCB and adesoldered controller. With my equipment, I‘m not able to reball.
Due to other priorities, it seems to be the final status
