I've got a faulty little Xantrex / Sorensen XPD 500W switching PSU. I wonder if anyone has found the schematic / service manual for the Xantrex XPD range or similar as I've only been able to find the user manual.
I haven't started debugging it yet. Will post more info once I have time to start, would be great to have the schematic
Unit is in good condition.
Symptoms:
- powers up, but whatever setting of the front panel V, A pots it stays reading 0.0 V, 0.0 A on the display. 0V measured at output. Remote programming and OVP not active
- activating and trying the remote V programming, I notice that it briefly switches to current limit mode when applying a voltage control if the current control is set low. Still all 0.0 reading. Seems like it is trying to output but shorted.
Anyone else tried fixing one of these?
