Since its driven by u228a
you may have some overcurrent situation / something is current consuming at some point OR
its friend with the under voltage ic u228B .... meaning you seem to / may have a triggering condition
Not sure about r317 r318, if they act as a slight inrush current limitter or "voltage dropper" and all of it is before the current sense resistors ... for the primary section
You have r221 who goes near r317 and goes to this ic u228a, for sure its a sense line return ...
yeah its a tough cookie psu loll, you have some pre-regulation circuit and the power circuit
you have 3 power supply sections, you have the small one (u64) who seems to give gives some clock to U21
, and you have its output line who goes on U287 opto isolator, who goes to U250
U287 must act as an ok supply to start U250
or some clock pulse is driven ?? maybe the 50-60hz detection ?? but it seems autonomous ?? man
you have to decypher circuit parts and try to figure out how they inter connect, in some cases say : you isolate 1 section and subs it with another dc source and try to see where it fails
you have p301 test points ? this is the dc voltage of the 1st power section ...
and the ususals checks for all the small voltages in this psu .. when its possible ... there could be a domino effect, one affect the other ....
