Author Topic: Xantrex/Sorensen XHR 40-25 schematic?  (Read 36038 times)
Offline ifonlyeverythingTopic starter
« on: November 17, 2023, 03:02:04 pm »
I've recently come into possession of a non-working Xantrex/Sorensen XHR 40-25 power supply. Does anyone happen to have a schematic? I tried searching Google but I can only seem to find an operating manual which doesn't include a schematic. The XKW series service manual/schematic is available but just looking at the board reveals significant differences...
Offline coromonadalix
Re: Xantrex/Sorensen XHR 40-25 schematic?
« Reply #1 on: November 17, 2023, 04:17:26 pm »
EDIT   see further away
so far  nothing from xantrex has ever leaked, or maybe some  as you suggest,   witch is rare ...
apparently  maybe  some lambda TDK  may have some similarities,  not sure for Sorensen
« Last Edit: November 18, 2023, 01:47:22 pm by coromonadalix »
« Reply #2 on: November 17, 2023, 04:25:51 pm »
That's unfortunate, I'll look around for anything TDK that might be comparable.
For anyone who has never seen the inside of these.... very EFFICIENT use of space near the output.  :palm:
« Reply #3 on: November 17, 2023, 06:51:37 pm »
If anyone is familiar with these beasts, I'd appreciate some hints on how the main DC-DC topology works. :) I believe there's a PFC boost upstream. I can see the mains rectifier and then two FETs and two diodes in parallel on the PFC side. On the downstream DC-DC I see four FETs with bootstrapped gate drivers (IR2110), followed by the transformer, output inductor, and output capacitors. But I'm not seeing any rectifiers?
« Reply #4 on: November 18, 2023, 01:47:46 am »
some power supplies use some kind of a buck boost / buck down configuration / pwm  configuration like / or ac phase control and have another section called the main regulator section
a mix of switching and linear modes ...  not sure if xantrex ones use something like this ??
on the bus bar you have a big black rectangle component,  could be an scr, triac  or bridge rectifier or even an big IGBT   witch would made sense  with the nearby ic's, and the thansformer who is in reality an huge inductor seems to confirm the operation
the linfinity  sg3524 is a classic  pwm ic
the uc3842 is a 500khz pwm ic too
IR2110/IR2113 are high voltage, high speed power MOSFET and IGBT drivers
« Last Edit: November 18, 2023, 01:57:18 am by coromonadalix »
« Reply #5 on: November 18, 2023, 03:50:10 am »
Wow, nice call. I thought it was just some sort of insulator but I checked it with my multimeter and it shows a 0.33V forward voltage on diode mode. So it apparently works, I guess, but I'd like to know WHAT part it is. Of course the identifier is on the fucking bottom, where it can't be seen without taking off the (+) bus bar... which means breaking the EMI ferrite glued around the bus bar in half and de-soldering and unbolting the clusterfuck that is downstream of the EMI ferrite. The engineers definitely did not design this with serviceability in mind. |O
« Reply #7 on: November 18, 2023, 12:14:56 pm »
Here's the service manual for the XHR series.
http://www.ko4bb.com/getsimple/index.php?id=download&file=06_Misc_Test_Equipment/Xantrex/Xantrex_XFR_Power_Supply_Manuals_and_NI_Drivers/Xantrex_XHR_Xantrex_XHR_600W_1KW_Service_Manual_TM-XR01-XN.pdf
Ed
THANK YOU.  :clap:
edit: The manual doesn't disclose the exact part # but their internal part # (CR-2040-PT) and description (ultrafast 200A 400V) appears to correspond to MURP20040CT.
« Last Edit: November 18, 2023, 12:44:45 pm by ifonlyeverything »
« Reply #8 on: November 18, 2023, 01:41:55 pm »
basicly  the psu topology is:  they rectify the AC,  PFC control/stabilize it in some cases, and with this huge DC line they PWM it ...
oh ho    check  "xantrex" on the given website  there is more   :-+
i did  use xantrex psu's in the past,  very efficient and compact, while being heavy  loll
years ago  when they broke, it was a dud to repair them, now i see  that we can do repairs at some point  ... i admit  i never redone any search  my bad  :palm:
and you seem to have some software too  for visa or control ??
« Last Edit: November 18, 2023, 02:24:14 pm by coromonadalix »
Offline Chris56000
« Reply #9 on: November 18, 2023, 03:52:08 pm »
 K04BB are taking a hell of a long time to sort out the manuals from their "Recent Uploads" directory – some of the files in there haven't been made available for download in over two months!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Online edpalmer42
« Reply #10 on: November 18, 2023, 08:12:58 pm »
Chris Williams
Remember that KO4BB isn't a group or a company.  It's a guy who pays for the storage space and bandwidth on his own and maintains the system in his spare time when the rest of his life allows it.  All things considered, I think he's doing a great job!
By the way, when did you last send a donation to help him cover his costs?  I sent him $50 a while back and he seemed very grateful.  Makes me wonder if that was an unusual occurance.
Ed
The following users thanked this post: FIXITNOW2003
Offline armandine2
« Reply #11 on: November 22, 2023, 02:23:43 pm »
If you don't want a scan, another link, worked for me - manuals - but no schematics
https://www.programmablepower.com/
https://www.programmablepower.com/products/dc-bench-power/xhr-series
[edited to manufacturer's links]
« Last Edit: November 22, 2023, 02:59:12 pm by armandine2 »
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Online coppercone2
« Reply #12 on: November 22, 2023, 05:28:21 pm »
lol check those sockets my sorensen (30V30A) had a bad socket on a op amp , even after I resocket it and clean the chip out etc.
nonsense happens until you push on the chip then it worked fine. if just wanna try some random whatever replace those socket
put some berylium copper or bronze pin sockets in there
i wonder if it could be because they got bus bar and big heat sinks like on the PCB
you can also disconnect the limiter circuitry totally (trimpot stuff) by disconnecting a resistor maybe. it should work fine. gets rid of that variable
as usual check the rails on the IC first before you start messing with the high current portion. I also took mine apart and cleaned/greased  the bus bars and bolts etc with deoxit grease or liquid depending on ease
but If I had to do another sorsensen switcher, I would literarly replace all the sockets before working on anything else, and I would not bother trying to test the socket (probobly lies when you probe it, mine did)... the whole thing with the probe on the bottom of the leg or under the PCB and a probe on the chip to measure continuity is BS for dodgy sockets that is not reliable troubleshooting IMO. i know there is some socket master voodoo priests in old computer repair but just IMO fucking replace that BS its not worth trying to analyze, you aint trying to preserve the vintage of some atari lol
here, take this
https://www.digikey.com/en/products/filter/sockets-for-ics-transistors/ic-sockets/409?s=N4IgjCBcoGwJxVAYygMwIYBsDOBTANCAPZQDaIALGGABxwDsIAuoQA4AuUIAyuwE4BLAHYBzEAF9CtAMyIQKSBhwFiZENOlwwAJkaENW7duZtOkHv2FjJIAKx05CpXkIlI5CgAZbnz8ZYgHFy8gqISUhqejmhYLqrulNT02hQg%2BjQ09GAI6TS22jRp6hkU%2BSaBZhah1lL0WtGKsSpu5NI%2BdTBFXgXSEFLlQeYhVuHgdbLQ8jHKrmq9cBRZRdI0MLYUCAGDVSM2YHWMk05Nswnzi33FaxsDlcNhNgC0xkdQ-ACuzWq2zOI2P5NWFAwGwgZAfDZOpMBAATLhgSJFbb3MSEdgAT1YuC4MOwKD%2BQA
« Last Edit: November 22, 2023, 05:47:16 pm by coppercone2 »
« Reply #13 on: November 23, 2023, 01:01:20 am »
Cleaned up the PCB a bit, didn't see any blown FETs, PCB scorch marks, or blown fuses. Need to get a light bulb limiter set up before I start investigating the power electronics further, and I think I want to test the control board separate since it's low voltage stuff (or just build an op amp test jig since it's all socket mount.) coppercone2 I'll be sure to focus on the sockets, some of them do look a little janky. Also managed to drop a fucking screw between that output capacitor clusterfuck, so I had to pull a few caps off to get the screw out -- needle nose pliers just jammed it in deeper. Might as well replace the output caps while I'm at it.  :palm:
In the meantime I'm still studying the schematic, trying to understand how it all works. I noticed the marketing material claims ZVS. Is this actually ZVS/soft switching? I'm no SMPS expert but the full bridge IC is just an SG3524 and I'm not seeing any evidence of any sort of ZVS detection circuitry... unless I'm missing something obvious?
« Last Edit: November 23, 2023, 01:07:58 am by ifonlyeverything »
Online coppercone2
« Reply #14 on: November 23, 2023, 01:08:20 am »
what was the problem with it to begin with? Not really sure how they work too well. I kinda figured out the feedback loop and figured where the fault might be.
but... power rails ok?
and my socket looked fine, it even removed OK, its just messed up. those socket suck because they are the 2 leaf things not the little hole
but you got a much harder supply because its 1kV. Mine is 30V. Anything over like 100 volts makes it mad complicated. 1kv exceedingly so. new failure modes for parts.  Even resistors can do that shit where they start failing at a high voltage like 750 volts.
Also mine had a mains connector that was not soldered in! it was press fit in for most of its life with almost no solder on the pin. It started arcing on me after I fixed the unit, luckily all it needed was a dash of solder. Sorensen QC must have had a bad day. I had enough HV shit since I fixed the miller dynasty welding machine (it has like 800V rail). Weird shit was going on there, far away insignificant looking components like ceramic caps causing problems.
Honestly the way to test this would be to desolder each part, bias it with HV supply, make sure its OK.. anything on the HV rail IMO can be really suspect but I don't have much experiance with that.
« Last Edit: November 23, 2023, 01:12:52 am by coppercone2 »
Online coppercone2
« Reply #15 on: November 23, 2023, 01:17:00 am »
lol if someone made me fix this, I would replace all the silicon on this thing and check all passives under HV and hope it works. stomach ache from thinking about the schematic . the only thing I know is that I would have to buy extra pace desoldering tips for this job
but for BS parts like 317, 347, gates, 351... its not really big money if you are patient and replace. that might give confidence enough to feel like you can trouble shoot it. for the gates that are like 10$ on ebay breadboard test it, but honestly with a desoldering tool, like a 1.5$ op amp.. Id just fuckin replace it.
if you can get it to a specific fault, it might limit the amount of trouble shooting.
probobly the diodes too.
only tip is clean the board from flux as you go along but not too clean and do a final clean when you are done
power transistors too, if they are cheap, replace IMO. If you gotta import it from bulgaria test it
if you do this crazyness, i recommend printing out the entire part list, getting two color of highlighter, and marking parts that might be suspicious with 1 color and another color if tested or replaced. but you need to test the HV parts with some voltage probobly or it might be another unknown.
« Last Edit: November 23, 2023, 01:24:21 am by coppercone2 »
« Reply #16 on: November 23, 2023, 01:29:02 am »
Previous owner said it would click on and off repeatedly with no apparent power. There's only one relay on the PCB (K139) which switches in/out 20 ohms of resistance to slow inrush current. I however didn't plug it in (yet.) Hopefully the problem is isolated to this relay, its power supply or its coil control logic, because these sections don't look TOO daunting.
Mine is only the 40V 25A model, so no worries about high voltage.
« Last Edit: November 23, 2023, 01:31:27 am by ifonlyeverything »
« Reply #17 on: November 23, 2023, 02:09:18 am »
you could be surprised,  dont assume thet psu is rinning on low voltages
normally the 120vac is rectified to at least 160vdc or doubled 320 347vdc  to create a stable dc supply to be  pwm'ed to the control stage ...
Online coppercone2
« Reply #18 on: November 23, 2023, 02:11:19 am »
oh yeah but its not a 1kV regulated output stage thankfully
« Reply #19 on: November 23, 2023, 02:22:52 am »
Oh yeah definitely, the PFC boost stage looks like it's putting out close to 300V.
Online coppercone2
« Reply #20 on: November 23, 2023, 02:23:48 am »
ok so if the relay is clicking on and off what does that mean.. how to recreate the problem
q215 is a low side driver for the relay. when it closes it energizes. something is causing that to open.u228a.
this is labeled overcurrent
the non inverting input is the input to this relay, the other shit is tied to rail. if rails are fine, so it has some shit going to ground, but the signal comes from r221 475k, which is tied to dc negative master, so the 18V rail goes through 1k1 to opamp input.
that op amp looks like its going into a rC delay for Q215.
so is this just a timer here? i think its also wired to the over voltage or whatever from the chip that connects to the shunt and the PSU
r294 to 297 is maybe a shunt for measuring current, goes into Isense on the chip
yeah idk its getting really complicated.'
But that is a clue, if its going over current protection, that might mean a shorted transistor some where I think... that chip might be measuring fine, and bad transistors are really common on power supply.
you can turn it on and probe that chip to see if its doing what its supposed to be doing. like measuring current and voltage
I think maybe just testing those transistors after the relay might be a good start, to look for damaged power transistors, possibly past the transformer. possibly at the output. i have seen more bad power supplies with just damaged power transistors then damaged control circuits, but I have seen power supplies that have damaged transistors and also control circuits. but the first one is more likely. and its likely if you find a bad transistor the control circuit for it might be damaged not some irrelevant one.
like sorensen has a good name, its considered reliable and high end, more then likely you don't have some deep control fault
it might be a transistor that is also connected to ground.like q114 h bridge
Q166 is like a crowbar or whatever, that abruptly sinks power if there is a fault to protect the output. this is the one you can disconnect and have a functional circuit still. r146 is like the front panel adjuster for the trip point.
test everything semiconductor in the top 1/5 of schematic page 95
« Last Edit: November 23, 2023, 02:34:52 am by coppercone2 »
« Reply #21 on: November 23, 2023, 08:15:50 am »
Since its driven by u228a
you may have some overcurrent situation / something is current consuming at some point  OR
its friend with the under voltage ic u228B  .... meaning you seem to / may have a triggering condition ???
Not sure about r317 r318,  if they act as a slight inrush current limitter or "voltage dropper"  and all of it is before the current sense resistors ... for the primary section
You have r221  who goes near r317 and goes to this ic u228a,  for sure its a sense line return ...
yeah  its a tough cookie  psu  loll,  you have some pre-regulation circuit  and the power circuit
you have 3 power supply sections,  you have the small one (u64) who seems to give gives some clock to U21 ???,  and you have its output line who goes on U287 opto isolator,  who goes to U250
U287 must act as an ok supply to start U250 ???  or some clock pulse is driven ??   maybe the 50-60hz detection ??  but it seems autonomous ??       man  |O
you have to decypher circuit parts and try to figure out how they inter connect,  in some cases say :  you isolate 1 section and subs it with another dc source and try to see where it fails
you have p301  test points ? this is the dc voltage of the 1st power section  ...
and the  ususals checks for all the small voltages in this psu .. when its possible ...   there could be a domino effect,  one affect the other ....  |O
« Last Edit: November 23, 2023, 08:36:51 am by coromonadalix »
Offline factory
« Reply #22 on: November 23, 2023, 06:43:29 pm »
These are known as the Glassman LVP series over here, they are 1kW not kV.
We had about a dozen rack mount version at 150V 7A at work, can't remember any dying, the fan packed up in one.
There was however a very nasty fault with one of them, the voltage set pot would jump the output to maximum, when it got to a dead spot on the ten turn pot.  :o
There is a bigger 150V 20A version & a newer 300V 9A unit at work, those can burn stuff very nicely, if you have a fault on the unit under test.  :-DD
« Last Edit: November 23, 2023, 06:48:47 pm by factory »
Offline Chris56000
« Reply #23 on: December 05, 2023, 07:30:22 pm »
Hi!
Update to my previous post – Manuals on k04bb now available for download!
Chris Williams
The following users thanked this post: coromonadalix
Offline NikiG
  • Country: bg
« Reply #24 on: December 12, 2023, 08:05:43 pm »
Hello, you maybe have problem in two components in corner?
Online coppercone2
« Reply #25 on: December 12, 2023, 11:09:11 pm »
lol where is waldo
watch that fixes it!
« Reply #26 on: December 13, 2023, 02:08:48 am »
Looks a little toasty, I'll have to check it. :) Unfortunately haven't had much time to work on this due to demands of my day job. I also need to order a new set of output capacitors and desolder/individually check the input capacitors and FETs.
Online coppercone2
« Reply #27 on: December 13, 2023, 03:25:00 am »
a burned out part is like a really strong guess that it might just work if replaced. and whatever that resistor is connected to also.
Offline NikiG
  • Country: bg
« Reply #28 on: December 14, 2023, 07:45:00 pm »
« Reply #29 on: April 10, 2024, 11:56:50 pm »
4 months later and I finally have a little free time to dick around with this. :) I replaced the capacitor that NikiG identified and fired it up. The relay clicked a bunch of times, the display flickered, the SMPS fired up for a second, and then it went back to flickering the display. I power cycled it a few times. No more relay clicks and the display is flickering. It's not powering up fully as I can't hear the fan run.
I can measure 170V DC across P2 so I know everything upstream is good. U21 (UC3842 SMPS IC) has an unstable VCC-GND voltage, fluctuating between 12V and 13V DC rapidly. I measured the voltage across C38 and I'm getting between 0.8V and 1.0V rather than the expected 18V. I measured the voltage across C35 and I'm seeing 7-8VAC at 60 hz which makes no sense.
This C35 output, I think it's supposed to be 18V, feeds the UC3854 PFC IC and the UC3524 full bridge IC. The UC3842 VREF output feeds the U64 ripple counter, which feeds the UC3524 full bridge IC. I measured this VREF and it's 0.8V to 1V, so nowhere near its intended 5V.
I'm not an expert with SMPS here but I assume something in this UC3842 section is having an issue here. Any suggestions on what I should measure next? I have a scope but I'm a little paranoid of using it since I don't have differential probes.
Online coppercone2
« Reply #30 on: April 11, 2024, 01:50:19 am »
how are you measuring the flickering voltage?
It bothers me. But its also a SMPSU IC. I don't know if those can make voltage flicker maybe if its switching something rapidly. I think that there is a problem here, but pulse loads can do weird things.
This usually means there is a bad capacitor. I assume its a linear regulator powering this IC?
If you see that much AC on a filter capacitor it might mean the capacitor is bad. Of course someone that works with that  chip might know for sure.
8VAC on top of a digital chip power supply rail seems like way too much
Fix that because it can make other things go really screwy. Like everything on that rail is suspect if its behaving like that. Or at least verify its normal some how  :-//
« Last Edit: April 11, 2024, 02:01:50 am by coppercone2 »
« Reply #31 on: April 11, 2024, 10:31:25 am »
I measured the 12-13V DC between pin 7 (VCC) and pin 5 (GND) of the UC3842. There's no linear regulator. The P2 connector is seeing 170V DC, which is fed through R14 to the VCC pin 7 of the UC3842. The auxiliary winding presumably takes over and feeds rectified voltage (diode CR16 and capacitor C22) to the IC, once it successfully starts up.
This is all further complicated by U64 which is acting as the oscillator for the UC3842 (pin 7 of U64 to pin 4 of the UC3842)... as well as acting for the oscillator for the UC3854 PFC IC and the UC3524 full bridge IC. I barely understand how U64 works but I think it implements a startup delay in addition to acting as the oscillator... so I have no idea how there is synchronization between UC3842 pulsing on with 170V DC, the auxiliary winding taking over, and the UC3842 somehow outputting a VREF stable enough to power U64.... which then takes some time to finally generate the oscillator pulse that feeds UC3842 RT/CT inputs... which it presumably needs BEFORE the auxiliary winding can fire?  :palm:
Maybe I'll try probing the Q11 gate and the Q11 sense resistor, to see if the switching waveform look normal at any point, and to see if excess current (from a short somewhere) is causing the IC to repeatedly loop through overcurrent shutdown and start up.
« Last Edit: April 11, 2024, 11:06:23 am by ifonlyeverything »
Online coppercone2
« Reply #32 on: April 11, 2024, 11:10:33 am »
But you said that is 6VAC on a digital rail that goes to UC3842.
it might have a wide range but VDD pins are usually DC voltages with not much AC component.
Even if its just a transformer secondary thats regulated it should be smoothish I think, not 30% ripple. if I read that right 30% ripple + 1VDC out of a VDC reference regulator means there is a problem. I would start with 30% ripple being a problem
« Last Edit: April 11, 2024, 11:12:35 am by coppercone2 »
« Reply #33 on: April 11, 2024, 11:36:55 am »
The low AC voltage I measured is across the smoothing capacitor C35 of the rectified auxiliary winding, which feeds the UC3842... as well as the PFC IC, full bridge IC, full bridge gate driver ICs, and several op amp power rails. Maybe I'll measure this with a scope as well. I initially measured it with my DMM, which refused to read anything on VDC but showed 7-8VAC at 60 hz on VAC mode. It has to be an artifact from things hiccuping and my DMM not being able to read fast enough. I have no idea why else I would be seeing 60 hz AC unless something is seriously fucked up.
Online coppercone2
« Reply #34 on: April 11, 2024, 11:42:37 am »
yeah, the capacitor !!! electrolytic capacitor not smoothing. news at 11
very common for caps to die and not do their job
The only thing that can cause a functioning cap to do this, is if the load is way greater then what that value capacitor can do. Capacitor value in a smoothing circuit is proportional to load. More load = bigger cap to get same ripple
unloaded it should be dead smooth
or the diode
i won't say that this is the only possible explaination, I think there might be some other possibility, but this is a VERY COMMON occurrence if its working as I described
« Last Edit: April 11, 2024, 12:14:40 pm by coppercone2 »
« Reply #35 on: April 12, 2024, 11:49:53 pm »
Pulled every electrolytic capacitor on the main PCB and they all tested fine on ESR meter: C22, C28, C35, C37, C39, C41, C77, C90, C100, C108, C289. Pulled Q11 and tested it on my transistor tester, looked fine.
I think my next step is to pull every diode, resistor, and non-electrolytic in this UC3842 circuit block and test for dead shorts. If nothing is bad then I'll pull just replace UC3842 and hope that works, because I have no clue what else it could be other than the transformer being bad (unlikely) or something pulling down the +18P rail (a ton of shit.)
Or maybe I could just unplug it from mains and inject +18VDC from my bench power supply at CR17 and see what kind of current draw I'm getting.
« Last Edit: April 13, 2024, 12:48:44 am by ifonlyeverything »
« Reply #36 on: April 13, 2024, 04:46:16 pm »
Pulled CR17 and F1, swapped R14 with a 10K resistor temporarily, and powered the downstream size of F1 with +30VDC with a 1A CC limit from my bench power supply. All voltages are looking nice and stable. Plugged in the secondary control board and the front panel, voltages were fluctuating and the front panel was visibly flickering. Unplugged front panel from secondary control board and voltages were still fluctuating. Looks like the problem is isolated to the secondary control board.  :)
Online coppercone2
« Reply #37 on: April 13, 2024, 06:22:43 pm »
ohhh I see its a totally different form factor then mine. i thought it was the single unit high pizza box
the schematics look very similar. but mine had 0 capability for isolation unless you want to cut traces. All I could do is unplug the GPIB card. I did not think of that trouble shooting technique
I forgot to mention, do you have crappy sockets in there for op amps? Because one of mine had a bad socket for a op amp. they are not machine pin, it had some really dodgy ass leaf socket
pic1 confirms you do have the shitty sockets.
Just thinking about it, flickering is sometimes caused by bad contacts. On those cable harness too. But I can't think of how it would cause the vref voltage to drop down to 20%
if you fix it you might wanna replace them all for 10$ before you put it back together, so you don't explode something later on.
I had the linear one in that form factor, the only thing I renember about it before I threw it out
1) it had something like 5 transistors working together on the output stage for the big power transistor, that is a bunch of 'passives' (do hardly any work with current). One of them broke. I replaced all of them and it started to work. I over tightened a chassis screw and caused a bolt to fry one of them again because a spacer was missing or not engineered in. it fried something again. Then traces started coming off during rework and i threw it out. if the power transistor breaks the ones around it break too
2) one of the wires on the IDC cable (insulation displacement cable) broke and came out of the harness. Clever method to weld the wire to the connector but I don't like it. you can't really poke it back in there, whole cable needs to be replaced or a solder fix has to be made with a external jumper wire. the crimp tool causes it to cold weld to the pin fork. once that breaks it done. its like wire wrap, not a crimp. the crimp tool is expensive
« Last Edit: April 13, 2024, 06:46:21 pm by coppercone2 »
« Reply #38 on: April 13, 2024, 09:03:24 pm »
Fed the secondary control board with my bench power supply, the 5V and 9V sections were fine. 18V and -18V had shorts, replaced the linear regulators U238 and U252 and the short went away.
Found out that main A3 board and the secondary A2 can have connection issues because the box headers aren't properly sized, meaning the pins will shift over 1 row... when this happens it will trip the auxiliary supply like before. Not sure if this caused the U238/U252 regulators to blow for the previous owner, but they did not blow for me.
I reassembled A2, A3, and the front panel and made sure A2-A3 connectors mated properly. Fired up the auxiliary power supply with +18VDC from my bench supply and it worked perfectly. All of the buttons on the front panel worked as expected, holding in V/I to set up a commanded V/I worked fine -- no drift in the numbers.
Re-soldered CR17, put F1 back in, swapped R14 for the 68K resistor. Reassembled everything. It fires up, front panel lights up, fans run, and there is an output voltage... but it's not working right.
I click in STANDBY and hold in V/I to set the V and I and the numbers will drift. They did not drift when I was powering it off +18VDC bench supply. I click out STANDBY to enable the output and I can hear a buzzing sound. Not sure if this is expected. Voltage refuses to go over 20V and it jumps around. Current limit is also acting strangely. It looks like the CC and CV limits are being obeyed but it just drifts around and won't stabilize. I'm using resistive loads.
Rear panel SW1 is in default configuration and I have J2 SNS- wired to the negative bus bar and SNS+ wired to the positive bus bar.
So... back to troubleshooting!  |O Will be sure to double check ALL of the sockets.
Online coppercone2
« Reply #39 on: April 13, 2024, 09:16:17 pm »
ok but if the regulators were shorted it might mean that there was a shorted load connected to them and that is why they maybe over heated and died after a while. like one of the op amps. or a cap shorted out and went open.
idk how to check the sockets though, replace. I had this bullshit where I pressed it in and it would work. then after i reassembly chassis it stop working. I open it up and push on chip it works again.
its like playing peek a boo with a troll
if you think you fixed anything by messing with the socket just replace the damn thing, its not reliable, i think you can get 30V randomly if the wrong socket goes up. meaning bye bye load (and a reason to fuse your prototypes even if your on a lab suply). i bought like 20 fuse holders and a whole set of fuses so I don't have to worry about malfunctioning opamps burning things
but thankfully when my op amp socket acted up, it dropped down to 3V max. idk how it decide on which set point to fall down to. maybe its built so it goes down to a low level if it fails, but I can't verify this... also it did once go to 17V when set to 15V I think, which caused a fan to burn out (otherwise tolerance circuit)
if your setpoint is acting up, that is either a reference drifting (it all based on reference), resistor divider or op amp malfunctioning.
or it might be nooise from a broken capacitor causing circuits not to settle (filter went haywire)
intermittant connector might cause things to dance around too. 14x+ magnification and a healthy dose of paranoia help find this problem
I think that really bad connector develop sensitivity to current load (resistance changes with load) and probobly temperature, which causes very minor motion due to expansion, makes it ACT up. *
*could it be a bad pin on a op amp making a very high impedance that ends up effecting the setpoint of a voltage circuit?
when your done fixing it, hook it up to a high current load (i.e. big ass resistor) and leave it on for a while to make sure it won't malfunction after 2 minutes and make danger
I have a feeling these power supplies probobly have distributed damage (lots of minor wear and tear) and that replacing stuff generally helps them. i think they basically get generally clapped out
when you screw in the pCB it gets flexed and stretched a little bit. might work when its out then stop working when you put it in. this is mechanical damage
the other thing you can do, recommended, is to reheat every solder joint on it, but it needs to be well fluxed. this means you need to do a big ass clean up after wards. I would do it for a 1kW supply though. but renember it needs to be well fluxed, and that means big cleanup. if you just do it dry to make it easy to clean it might not help things. like probobly a few hours of scrubbing to get it really nice, and you possibly loose some text and component indicators if your not careful. if you carefully apply flux, on both sides, and clean as you go, its not much worse then other penal labor >:( . And heat can reveal problems, so you need to grid the board and test in between doing squares if you want the most benefit and highest success rate from this method to say.. maybe identify a bad bond wire or something from heat. where it goes from intermitant to broken. if you do it all at once you can get a fix, but you won't know where.
« Last Edit: April 13, 2024, 09:37:26 pm by coppercone2 »
« Reply #40 on: April 14, 2024, 01:01:25 am »
You were right about something killing the regulators. I think the -15V regulator is blown (it's outputting roughly -18V instead of -15V) and the 15V regulator is running super hot because something is pulling it down to 8-9V. Auxiliary power supply output is still fine. Will dick around with this later but I'm guessing the OP07 block is screwing me over, since that's where the blown open tantalum capacitor was found.
Online coppercone2
« Reply #41 on: April 14, 2024, 01:11:07 am »
thermal imager might come in handy here . seek thermal
or probing stuff (its fucking annoying though)
« Reply #42 on: April 15, 2024, 11:56:42 pm »
Thermal camera didn't reveal anything unexpected. Only thing heating up were the linear regulators and a couple small value resistors on the 6.2V zener and the linear regulator. The zener was regulating fine. I replaced the linear regulators and powered it off my bench supply, didn't pull above like 0.05 amps at idle (due to those small value resistors.) Connected everything back up same problem with U238 being pulled down and U252 instantly shorting out. One of the output capacitors (new Nippon Chemicons from LCSC) blew the fuck up too.  :palm:
« Reply #43 on: May 04, 2024, 12:47:26 am »
I'm not sure why it didn't pop up on the thermal camera before but C239 was hitting 50C so I swapped it with a new through-hole ceramic cap. I replaced the output capacitor that blew and replaced the linear regulators with brand name versions because I realized my stock were counterfeits I bought from eBay years ago.
I did some light load testing and I believe it is working. Horrible transformer buzzing is gone. Linear regulators U238 and U252 are cool to the touch and are outputting the correct voltages. U257 is running quite hot at 80C case temperature but it's not heatsinked as per design. It feeds the fan and I measured the fan pulling 100 ma, so I guess it's just engineered to run hot.
I need to mess around with some of the trimmers because the output voltage is half a volt more than the CV limit, but everything looks stable at a few hundred watts load. Just need to come up with a way to test it at its rated 40V and 25A.
In summary: C151 visibly blown; C239 shorting causing U238 and U252 linear regulators to short or blow; U257 linear regulator replaced preventatively; output capacitors C137, C140, C141, C143, and C162 replaced preventatively; new C137 capacitor blew so it was replaced again.
Online coppercone2
« Reply #44 on: May 04, 2024, 01:27:49 am »
nice I had to take mine apart to wash it the other day because coolant spilled on it because it was bein used as a table for a pump (non conductive  but still)
are all those caps electrolytic or other types?
« Last Edit: May 04, 2024, 01:29:24 am by coppercone2 »
« Reply #45 on: May 04, 2024, 02:34:20 am »
C151 and C239 were tantalum, replaced both with ceramics from my eBay TH ceramic kit. The others I replaced were electrolytics.
« Reply #46 on: May 04, 2024, 04:27:53 pm »
The problem of a buzzing transformer and fluctuating output voltage is back -- except this time the linear regulators are still working fine! Applying pressure to the top of the unit apparently causes this problem. It looks like this flexes the super shitty IDC box headers they used to join the A2 and A3 PCB. I can't easily Ohm this out so I guess I'll just replace it. The PCBs all have thick insulating paper underneath and they definitely are not cracked, so I don't think it's mechanical pressure inducing a short or open circuit or anything like that.
« Last Edit: May 04, 2024, 04:36:36 pm by ifonlyeverything »
Online coppercone2
« Reply #47 on: May 04, 2024, 07:28:23 pm »
yeah xanatrax sorenesn IDC breaks I seen it pop out before but that is a cold welded cable (it cold welds the wire to the fork via the crimp tool), its like a crimp spot weld.
some people touch it up with solder but it might be difficult
the bond area for those IDC cables is basically the area of two prongs of a sheet metal fork (the thin inside part of the fork, like between fingers (bronze I think, maybe steel), once it goes it goes
just reseating the wires with a screw drivers is a temporary solution, your not remaking the cold weld. its the same technology as this
https://telcodepot.com/premium-punchdown-tool-1328
« Last Edit: May 04, 2024, 07:30:52 pm by coppercone2 »
« Reply #48 on: May 05, 2024, 12:11:21 pm »
The A2-A3 board connection is done with a box header to box header connection -- there is no IDC cable. Anyways, I was targeting the wrong area. It was the damn tab-mount snubber on the diode being slightly bent, just enough to ever so slightly contact the case of the power supply when mechanical pressure was applied! :palm: I bent it downward, toward the PCB, and the problem is now gone.
Now to get some Nichrome wire for a load test and to figure out how to trim out the error between CV and measured output voltage. The error is 0.1V for CV <9V; 1.2V for CV of ~24V; and 0.6V for CV of 36V. So that is definitely strange.
« Last Edit: May 05, 2024, 12:19:39 pm by ifonlyeverything »
Online coppercone2
« Reply #49 on: May 05, 2024, 10:22:41 pm »
well that cable is insulation displacement (IDC) did you see how the crimps are made? Not sure if it works exactly like a MTA crimp (individual press in), but it does cut through ribbon cable insulation. you don't strip that
there is a tiny fork that cuts the insulation and then I assume cold welds itself to the wire in a tiny point pressure point.
to make those cables you just lay it in unstripped...
I never saw a soldered version of it in any test equipment, definately not in any xantrax or sorensen I worked on (numerous)
« Last Edit: May 05, 2024, 10:29:32 pm by coppercone2 »
« Reply #50 on: May 07, 2024, 01:30:11 am »
Been trying to understand the CV offset issue for a day or two, kind of stuck. Would appreciate any help. It's a variable offset (see below for examples) and I have discovered two scenarios that will create this problem.
At a CV of 36.0V I see a swing up to 36.8V. Delta of 0.8V.
At a CV of 22.5V I see a swing up to 23.9V. Delta of 1.4V.
At a CV of 12.4V I see a swing up to 13.1V. Delta of 0.7V.
Scenario 1:
STANDBY enabled.
I click V/I and dial in my CV limit of 22.5V.
STANDBY disabled.
I click V/I and my commanded CV limit has changed to 23.9V.
Notice the change from 2.755V to 2.920V, an offset of +0.165V.
Scenario 2:
STANDBY enabled.
STANDYBY remains enabled.
REMOTE programming enabled.
R230 measures 10K and the voltage drop across it at all times in all of these scenarios is 0.000V -- it's not a source of current being injected.
This is what the 10-turn (R35), V/I check button (SW75A), REMOTE button (SW73), and STANDBY button (SW74) are doing on the front panel. Keep in mind clicking V/I doesn't change the value on the non-inverting pin (as per my measurement), it just does an analog to digital conversion and displays it on the front panel.
« Last Edit: May 07, 2024, 11:10:10 am by ifonlyeverything »
« Reply #51 on: May 26, 2024, 12:00:21 am »
Spent some more time playing with this. I've pinpointed it to Q194 causing VCTL to droop when shutdown is enabled i.e., Q194 is pulling the non-inverting pin of U199D (pin 12) to ground. I wonder if this is a "design flaw." The worst delta is at around 22.4V (swings up to 23.9V for a 1.4V error) and is around 6% so it's not too bad. Just annoying that it exists in the first place.  :-\
My guess is that increasing R219 would help (and decreasing C220) but I don't particularly feel like finding out what other potential downstream impacts might be...
« Last Edit: May 26, 2024, 12:02:04 am by ifonlyeverything »
