Hi all,
I'm in the process of repairing a friend's Xbox 360 E. The unit wouldn't power on at all and some corrosion by the USB ports led my investigation there. I discovered that the 5 V and GND pins for the USB ports were shorted. I desoldered the (what I assume from googling is a 100 nF bypass cap) and the unit now powers on normally and the short had been removed.
I assume I need to replace this capacitor. So my question is: any ideas on what an exact value might be or some best guesses as to the value? My DE-5000 says it's reading 1.5 pF but I'm not putting too much stock in that reading as I believe the cap is faulty, to begin with.
I attached a mediocre image from my phone in case that can help provide any more helpful context/info.
Thanks!
Best,
Matt
