Hi Everyone. Maybe someone could help?
I have been given a box of old gaming controllers from a local gaming shop that went out of business.
I have been going through them and fixing what I can, however 19/23 Xbox One controllers all appear to have this same common failure. The fault being they are dead, no power, no life at all, zip, nada!
Apparently these were all brought in by customers that said "they just wouldn't switch back on".
So I tried them all via USB power, a few of them work using a USB cable but via battery there is absolutely nothing at all.
So I hooked each and every one up using my bench power supply onto the battery terminals. Setting it to 5V as indicated on the label on the controller then creeping the current up slowly. (Max 480mA indicated on the label on the controller).
The result is that 100% of them cause the power supply voltage to drop to 0V and it goes into constant current mode.
So to me it seems like a dead short somewhere.
Has anyone got any experience with these at all that could point me in the right direction?
Any service manuals or schematics?
Most of the controllers are "Model 1537" and two of them are "Model 7697".
Thank you!
