Author Topic: XBox One S - No Power On - Missing 3.3V  (Read 2133 times)
Offline LiftedTrace
« on: November 24, 2019, 06:52:06 pm »
Hello all, I am at it again. This time a friend of mine came to me with a dead xbox. I figured, its already dead why not poke around and see if I can find out why.
Im new to this stuff and would like your input on if what I am thinking is correct.
I started by checking if the main + and - were shorted, and they were not.
I plugged in 12V to the main and started checking voltages at the test points. I have the 12V and 5V but not the 3.3V.
The main 3.3V comes from the 12V it seems from what I show in the pictures. I am getting .8V on the output of the coil. SO i was thinking, maybe something is shorted, dropping the 3.3 down to .8, so I decided to put 3.3V directly on the test point to check if the voltage got pulled down, and it did not, and drew very little current.
Seen as there is not much around this area, I was suspecting this little chip is not working as expected and not producing its 3.3V.
Your thoughts?
I also have no clue what this chip is, I cannot find any info on it to really test further.
Anyone have any direction I can go?
Offline fzabkar
Re: XBox One S - No Power On - Missing 3.3V
« Reply #1 on: November 24, 2019, 07:20:57 pm »
NB671GQ, Monolithic Power, Synchronous Step-down Converter, 5V - 24Vin, 6A, marking AEAy, QFN-16:
http://www.mouser.com/ds/2/277/NB671_r1.04-371602.pdf
Check the Enable pin to see whether the IC is being switched on.
The following users thanked this post: LiftedTrace
Offline LiftedTrace
« Reply #2 on: November 24, 2019, 10:05:03 pm »
Awesome, Thank you.
I checked the enable pin and its low (.09V). So now I just have to try and find what is supplying that voltage. I have no clue where its coming from and it very quickly vanishes thru the board.
Looks like I have a nice hunt on my hands.
I'm half tempted to open mine up and take some reference measurements.
I'm afraid it might be coming from one of the main chips and if thats dead, maybe thats why its not enabling the 3.3V
Offline fzabkar
« Reply #3 on: November 24, 2019, 10:08:08 pm »
Could we see a photo of the whole PCB?
Offline LiftedTrace
« Reply #4 on: November 24, 2019, 10:44:06 pm »
Absolutely. Here is the front and back. If you would like higher res, let me know. This is as good as my phone takes.
I marked the chip that provides the 3.3 with a red X....upper left side of the board on the front.
Offline LiftedTrace
« Reply #5 on: November 24, 2019, 10:50:43 pm »
I poked around the near by power supplies with the continuity mode, trying to poke everything I seen to try and find where that enable trace is going off to, but I didn't find anything.
Offline fzabkar
« Reply #6 on: November 25, 2019, 12:35:20 am »
Does the IC get a proper Vin supply?
I would measure the voltages at the large electrolytic capacitors, both leaded and surface mounted. Also measure the voltages at the inductors (Lnnn). These will be the inputs and outputs of the various switchmode regulators.
Also check the fuses, eg RT3F1, RT6B1, RT6B2. These have a Littelfuse logo (Lf).
There are several 5-pin chips which look like linear regulators or maybe load switches, eg U5D2 and two others near the bottom left edge of the PCB. Can you measure their inputs and outputs? Can you identify their part markings?
Offline fzabkar
« Reply #7 on: November 25, 2019, 12:57:25 am »
Offline LiftedTrace
« Reply #8 on: November 25, 2019, 01:22:06 am »
Yeah that was my failed attempt at trying to repair an ebay item. It was a lost cause. This one of my friends my be a lost cause too.
Offline fzabkar
« Reply #9 on: November 25, 2019, 01:35:08 am »
If you want to keep plugging away, we'll see how far we get this time.
Offline LiftedTrace
« Reply #10 on: November 25, 2019, 02:07:02 am »
Ok so, The Vin on the suspect chip is a solid 12V. The enable pin is not getting its voltage and I do not know where its coming from yet.
U5D2 looks to be getting its input from the output of the large coil next to the chip with the red X on top (the chip not getting its enable voltage)
U5D2 has no output voltage.
The two identical 5pin chips in the lower left also get their input from the large coil next to the red marked chip. These also have no output on them.
There is a dead short between the output of the coil and the inputs of those chips. I gave the 3.3v test point a low limited current 3.3v and I didn't see any drop in voltage, so I don't think something on the 3.3v side is pulling it down.
Oh and all the fuses checked out good.
This site: https://www.electronicproducts.com/Xbox_One-whatsinside_text-158.aspx
Was pretty helpful in finding some stuff, like them lower left 5 pin chips.
These chips were marked with: P6243WG and that site lists its part number as CAT6243DCADJ?RKG
Chip labeled U5D2 has marking of GK1DQ828 and I cannot find any info on this, but I assumed the input was the pin with the same voltages as the inputs on the other two chips and what the large coil was outputting.
Offline LiftedTrace
« Reply #11 on: November 25, 2019, 02:08:36 am »
I enjoy this, Ill  :horse: until all options are exhausted  :-DD
Offline fzabkar
« Reply #12 on: November 25, 2019, 02:56:57 am »
That's a great teardown.
P6243WG is an adjustable linear regulator with an Enable pin (1). If there is no Vin, I would think that the Enables would be inactive, too.
I think if you continue on this path and map out the relationships between each of the supplies, then you can build a picture of the power layout for the PCB. Clearly there must be a main supply which powers whichever chip is responsible for enabling the NB671GQ. Maybe you will find other regulators with missing enables, and this may then give us a better idea of the source.
Just keep measuring the coils and large capacitors.
Edit:
U5D2 is an LDF adjustable regulator. Pin #1 is the enable.
LDF, STMicroelectronics, adjustable LDO regulator, 1A, 2.6V - 16Vin, PPAK-5:
pdf.datasheetcatalog.com/datasheets/stmicroelectronics/LDF_LDFPT-TR_LDFPVR_LDF33PT-TR_to_LDF25PT-TR.pdf
CAT6243DCADJ-RKG, ON Semiconductor, LDO Regulator, Adjustable, 1A, 2%, marking P6243WG, DPAK-5:
https://www.onsemi.cn/pub/Collateral/CAT6243-D.PDF
« Last Edit: November 25, 2019, 03:17:59 am by fzabkar »
Offline LiftedTrace
« Reply #13 on: November 25, 2019, 03:05:49 am »
Do you think it possible these have the same enable inputs? I i remember correctly, the P6243 didnt have anything on the enable either. I just ignored it cause the Vin was gone too.
Offline fzabkar
« Reply #14 on: November 25, 2019, 03:20:58 am »
It would be helpful to know the state of Vin and Enable for each of the regulators. You will find additional switchmode regulators alongside the coils.
Offline LiftedTrace
« Reply #15 on: November 25, 2019, 03:31:02 am »
Ill take some readings and document as much as I find. It might be a few days with Thanksgiving coming up and long work days. Il post back as soon as I can.
Offline fzabkar
« Reply #16 on: November 25, 2019, 03:39:46 am »
If you can write up the markings on the chips, I can produce a BOM for you. Then you'll have something to work with.
Offline LiftedTrace
« Reply #17 on: November 25, 2019, 03:46:36 am »
Ill take a higher res image and jot down the voltages on the image. any un readable chips, Ill type in over them. Might take me a few days.
Thanks for the help.
Offline LiftedTrace
« Reply #18 on: November 27, 2019, 04:12:27 am »
Here is a link to a higher res image: https://www.dropbox.com/s/db9q1sntkaq0whq/XBOX%20Front%20Voltages.jpg?dl=0
I took a few measurements and put them on the chips.  The font is very small, about the size of the chip leads them selves. You need to zoom all the way in to see them good.
I didnt measure the 3.3V  chip ( not sure why I didnt do that one first  |O )
I find it very strange the EN pin doesnt seem to have any input to it. I cannot find where it goes.
The chip itself is getting 12V supplied to it though.
I am half tempted to take a resistor and tap off the 12V rail and see if I can even get the chip to turn on and output 3.3 manually.
The following users thanked this post: fzabkar
Offline fzabkar
« Reply #19 on: November 27, 2019, 10:43:45 am »
Here is the BOM so far:
LM339A, Texas Instruments, precision quad differential comparator, 2V - 36V, +/-1V - +/-18V, marking L339A, SOIC-14:
http://www.ti.com/lit/gpn/lm339a
TPS51916, Texas Instruments, Complete DDR2, DDR3, DDR3L and DDR4 Memory Power Solution Synchronous Buck Controller, 2-A LDO, Buffered Reference, 3V - 28Vin, 0.7V - 1.8Vout, QFN-20:
http://www.ti.com/lit/gpn/tps51916
TPS53819A, Texas Instruments, 3V - 28V Input, 40A, Eco-Mode, D-CAP2 Synchronous Buck Controller with PMBus, marking 3819A, QFN-16:
http://www.ti.com/lit/gpn/tps53819a
SN75DP159, Texas Instruments, 6-Gbps AC-Coupled TMDS to HDMI Level Shifter Retimer, marking 75DP159, WQFN-40:
http://www.ti.com/lit/gpn/sn75dp159
NT5CB256M16EP-FL, Nanya, DDR3 SDRAM, 4Gb x 16, 1.5V, 2133Mbps, BGA-96:
https://www.nanya.com/en/Product/3994/NT5CB256M16EP-FL
https://dl.khadas.com/Hardware/VIM1/Datasheet/Amlogic_STB_Release_V3.3_QPL20170609-Wesion.pdf
AON7403, Alpha and Omega, P-ch MOSFET, -30V, -29A, 18mOhm Rdson, marking 7403, DFN-8:
http://www.aosmd.com/res/data_sheets/AON7403.pdf
KLM8G1GEME, Samsung, eMMC, 8GB, 64Git x 1:
https://www.samsung.com/semiconductor/global.semi/file/resource/2017/11/Samsung_eMMC_2013-0.pdf
THGBMFG6C1LBAIL, Toshiba, eMMC NAND Flash, 8GB, 1 x 64Gbit, 3.3V / 1.8V, BGA-153:
https://www.es.co.th/Schemetic/PDF/THGBMFG6C1LBAIL.PDF
NTMFS4C55N, ON Semiconductor, N-ch Power MOSFET, 30V, 78A, 3.4mOhm Rdson, marking 4C55N, SO-8:
https://media.digikey.com/pdf/Data%20Sheets/ON%20Semiconductor%20PDFs/NTMFS4C55N.PDF
1812L150/24, Littelfuse, Polyfuse, 24V, 1.5A, marking LF150-24:
http://www.littelfuse.com/products/resettable-ptcs/~/media/Electronics/Datasheets/Resettable_PTCs/Littelfuse_PTC_1812L_Datasheet.pdf.pdf
AP2127K-ADJTRG1, Diodes Inc, 300mA HIGH SPEED, EXTREMELY LOW NOISE CMOS LDO REGULATOR, marking GEH, SOT23-5:
https://www.diodes.com/assets/Datasheets/AP2127.pdf
PMBT2222A, NXP, NPN transistor, 40V, 600mA, marking W1P, SOT23-3:
https://assets.nexperia.com/documents/data-sheet/PMBT2222_PMBT2222A.pdf
SSM3K324R, Toshiba, n-ch MOSFET, 30V, 4A, 1W, 56mOhm Rdson, marking KFD, SOT23-3F:
https://media.digikey.com/pdf/Data%20Sheets/Toshiba%20PDFs/SSM3K324R.pdf
SSM3J331R, Toshiba, p-ch MOSFET, -20V, -4A, 55mOhm Rdson, marking KFO, SOT23-3F:
https://toshiba.semicon-storage.com/info/docget.jsp?did=13019&prodName=SSM3J331R
NCP5901BMNTBG, ON Semiconductor, dual MOSFET gate driver, marking AZx, DFN-8
http://www.onsemi.cn/pub_link/Collateral/NCP5901B-D.PDF
SP1004U-ULC-04UTG, Littelfuse, TVS Diode Array, 0.20pF, 20kV, 9.2V clamping, marking 4C, 1004 DFN:
https://www.littelfuse.com/~/media/electronics/datasheets/tvs_diode_arrays/littelfuse_tvs_diode_array_ultra_low_capacitance_diode_arrays_datasheet.pdf.pdf
B130LAW-7-F, Diodes Inc, Schottky rectifier, 30V, 1A, marking SX, SOD123:
http://www.diodes.com/datasheets/ds30308.pdf
MP8757, Monolithic Power, Synchronous Step-Down Converter, 7A, 5V - 18Vin, marking MPyw + 8757, stepdown converter, QFN-21:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP8757/document_id/905/
TPS51206, Texas Instruments, 2A Peak Sink/Source DDR Termination Regulator with VTTREF Buffered Reference for DDR2/3/3L/4, marking 1206, WSON-10:
http://www.ti.com/lit/gpn/tps51206
SN74LVC1G08DBVR, Texas Instruments, single 2-Input AND Gate, 1.65V - 5.5Vin, marking C08F, SOT-23-5:
http://www.ti.com/lit/ds/symlink/sn74lvc1g08.pdf
MP2161GJ, Monolithic Power, Synchronous Step Down Switcher, 2A, 2.5V - 6Vin, 1.5MHz, 17uA IQ, marking AEBy, TSOT23-8:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP2161/document_id/450
RT5785AGJ8F, Richtek, synchronous step-down DC-DC converter, 2A, 2.5V - 6Vin, 25uA IQ, marking ON=, TSOT-23-8:
https://www.richtek.com/assets/product_file/RT5785A=RT5785B/DS5785AB-02.pdf
« Last Edit: December 02, 2019, 06:45:14 am by fzabkar »
The following users thanked this post: zzattack, LiftedTrace
Offline fzabkar
« Reply #20 on: November 27, 2019, 11:54:28 am »
UC43 appears to be configured as a 5V regulator. There is a "5P0" test point below capacitor C4D1. ISTM that this part of the circuit is working correctly.
As for the chip's identity, all I know is that it is a stepdown converter made by Monolithic Power.
Offline LiftedTrace
« Reply #21 on: November 27, 2019, 02:15:33 pm »
Yes the 5v seems to be working as expected.
I also have the 1.1STBY.
Anything that seems to get its main power from that 3.3V is shut down.
Now here is a question.
U4C2 turns on with a high EN. The data sheet says over 1v with a max of 12.
It’s currently got .2v.
So if the chip is off, how is it producing .8v on the coil L5C1?
I would think L5C1 should be 0v just the the others that are not currently on.
Offline fzabkar
« Reply #22 on: November 27, 2019, 04:52:20 pm »
I can't understand why there is 0.8V there, either.
I notice that the Vout (pin 5) of U3D6 is low. Is something shorting its output to ground, or is the IC faulty? BTW, I don't see any feedback resistors on pin 4 (ADJ). Perhaps they are on the other side of the PCB?
It might help to compare this PCB with your water damaged one. A similar hires photo could help us to identify the date and batch codes from the part markings.
Edit:
FWIW, page 3 of the Xbox 360 circuit diagrams shows the reset logic for that PCB. Many of the power enables come from its Southbridge, so I'm guessing that the X861949-007 (Microsoft XBOX ONE ASIC) may be the source in our case.
https://elektrotanya.com/xbox_360_xenon_retail_rev_k7_fab_k_sch.pdf/download.html
Edit 2:
It may be obvious to some, but the circuit references include the PCB coordinates. I just worked it out now (doh!).
The PCB is laid out in a grid consisting of columns numbered from 3 to 9 running from left to right, and rows from B to G running from top to bottom.
A part is identified as type-column-row-number.
For example, C5E10 is a capacitor, C10, located at column 5, row E.
« Last Edit: November 27, 2019, 10:23:47 pm by fzabkar »
Offline LiftedTrace
« Reply #23 on: November 28, 2019, 03:52:17 am »
I had no idea, that's great for pointing that out. Makes for finding things much nicer.
So I just spent some time looking thru that xbox break down site and trying to find what ever chip U3d5 was, and the only thing I found was TPS206x in the DVB package. This lists the Output as Pin 1 and the input as Pin 5. I dont think this is the correct chip because I got almost nothing on the input, but almost 5V on the output.
I also cannot find out what U4D4 is from that site either.
As for the feed back resistors for U3D6, there are two resistors on the back side in very close proximity to the power supply package of components.
I am not sure this is where the problem is though, only for the fact that the small coil near all this it outputting 1.136V, and there is a test point right by there labeled TP1P1STBY which has 1.136V on it. Also very close to that is the test point for the 1.8V labeled 1P8STBY (Location TP4D4) which is reporting only .089V. Now Im no expert at this, but if this is a STBY voltage coming from some power supply, should I be reading 1.5_Ohms between this TestPoint and ground?
So, I cannot seem to find out where this 3.3V chips EN is coming from which makes me think it may be coming from the big kahuna (U4D2 ) The Xbox One chip. It may be possible that the 1.8V supply is shorted somewhere and the main chips knows it and is not allowing the rest of the machine to power up. If that is the case, How could I find out what is shorted? And is it possible its the main Xbox One chip itself which is shorted?
Maybe its time to give the 1.8V a current limited 1.8V on its testpoint and see what gets warm?
EDIT:
Ok, so I got impatient, I went ahead and gave that 1.8V test point the voltage it was wanting, with a 100ma limited current. There was absolutely no drop in voltage when I gave it 1.8V, and I cant seem to find where its coming from because when I check with Ohms, its virtually a short.
I seem to be stuck.
EDIT 2:
So I connected main power again and now I have 1.8V |O , and when I measure the resistance (power off) I get 71_Ohms.
How is this possible? Go from a dead short, to 71 Ohms?
EDIT 3:
The 1.8V seems to be coming from U3D6, the one you were saying the Output (pin 5) was a bit low.....its no longer sub .1, but 1.8, and pin 4 is also now at .8v  :-// :-//
Maybe my hitting the test point with 1.8V scared it straight?
The 3.3V is still out of commission though.
EDIT 4:
Ok so I decided to pullup the enable pin on the 3.3V power supply and see if it kicked on....and it did!  :box:
But none of the others started working, because they also are missing their enables.
I dont know, I am really leaning towards the main Xbox chip being gone. None of the enables are tied together, so they must be getting their input from some control chip. and since there really is not much other than the large XBox chip and some power supplies, I am not sure what more I can do for this thing.
I could Frankenstein the thing and force all the chips to turn on by pulling up all their enables.....just to see if it boots, but not sure its worth it.
« Last Edit: November 28, 2019, 11:50:49 pm by LiftedTrace »
Offline fzabkar
« Reply #24 on: November 29, 2019, 09:10:00 am »
I don't think it is a good idea to backfeed the supply voltage into the outputs of your regulators.
Have you checked all the other supply test points? Is your 3.3V supply the only one that is missing now? I suspect that the 1.5 ohm short may have been due to an MLCC (ceramic cap).
Offline LiftedTrace
« Reply #25 on: November 29, 2019, 03:55:58 pm »
There are many that are not turning on, but some of them I suspect will never turn on until the power button is pressed and the whole thing wakes up. I just do not know which ones those are that should be in all the time, and those that only come on at power up.
It may be time to take my working one apart and use for a reference.
As a side thing, there was clearly something wrong with the output of U3D6, or what ever makes it tick. Do you know the part number of that thing?
EDIT 1:
Ok well I am  |O
When it occurred to me that other power supplies were not turning on until power up, I connected the power button board, and low and behold! The 3.3v I was missing suddenly came to life  |O |O
The enables for that 3.3 chip ( U4C2 ) is not present, as well as the enables for the two on the lower left ( U3F1 and U3E1)
AND!, when I press the power button, I get a beep sound as it’s powering up, and the shuts down right away.  So it seems my problem is not what I thought after all, lol.  :horse:
Also that strange 3.3v issue seems random. It dropped back to .8v again and then back to 3.3.
There is clearly something wrong with that section. But while it is working and the board powers up, I see some power supplies spike for a second and then the whole unit powers down.
When I power up, I see no increase in current draw but 20ma, so I do t think I have a short. I wish I did, it might make this easier to hunt down.
So clearly something is not seeing the correct voltage and it’s shutting back down.
The main 12v supply for the APU doesn’t even hiccup at power up, so either that is a delayed start after the rest of the board chimes in as ok, or my issue is over there.
One mosfet ( Q9D1 ) goes low on the gate when powerup.
I see a spike on its output for a brief time. I’m going to try and track that down and see where it goes.
It doesn’t seem to be tied into the three groups of fets for the APU supply, but I suspect maybe it enables them some how.
« Last Edit: November 29, 2019, 04:59:05 pm by LiftedTrace »
Offline fzabkar
« Reply #26 on: November 29, 2019, 06:13:50 pm »
U3D6 appears to be marked as "GEH", in which case it is in my BOM.
Offline LiftedTrace
« Reply #27 on: November 29, 2019, 10:25:02 pm »
Sorry, I missed that. Thanks.
I no longer have that xbox. The only other one I have is my own working one and I am still on the fence for opening it up or not.
I don't know how the two are tied together, the enable of U4C2 and the output of U3D6, but there is a shady looking cap on the back side of U4C2 (the 3.3V chip) that is connected to its enable pin, and I was pretty sure last I checked it, it measured short to ground. Maybe that cap is intermittent problem for why the 3.3v is sporadic. And every time the 3.3v chips gets a good enable, the output of U3D6 is also good.
There are still some test points that do not turn on. I am trying to track down where Q9D1 goes off to. That closes when it powers up and then the system shuts down. I am thinking maybe the power from that is not getting to its intended destination. That's my theory anyways. I follow it into the enables of the three small chips U9D2, U9E1, U9E2. Those I suspect control the power for the 12v for the APU and I do not even see a blip of turn on when the box is powered on. It might also be nothing.
Here is a higher res stitched together photo with more readable text. : https://www.dropbox.com/s/k1f7ol4rekuwrwq/XBOX%20Front.jpg?dl=0 Seems my browser wont open that file, probably to large. Might have to be downloaded.
EDIT 1:
So I located what controls U9D2, U9E1, and U9E2. Its the larger chip NCP4205 (U9C2 ). Its coming from pin 28 on that chip. I looked thru google results for any type of datasheet but cannot seem to locate anything and I didnt see it on you BOM. I was hoping to back track thru and find out whats going on, but without a description of those pins, I have no clue if its working as intended.
« Last Edit: November 30, 2019, 12:13:30 am by LiftedTrace »
Offline fzabkar
« Reply #28 on: November 30, 2019, 01:08:42 am »
Is it possible that the NCP4205's enable output is actually an enable input? That is, is the NCP4205 also being controlled from some other chip?
FWIW, here are datasheets for chips with a similar part number:
NCP4200, ON Semiconductor, Programmable Multi-Phase Synchronous Buck Converter with I2C Interface, 8-bit VID DAC, 4 x PWM, Vin = 5V, QFN-40:
https://www.onsemi.com/pub/Collateral/NCP4200-D.PDF
NCP4201, ON Semiconductor, Programmable Multi-Phase Synchronous Buck Converter with PMBus, 8-bit VID DAC, 4 x PWM, Vcc = 5V, QFN-40:
https://www.onsemi.com/pub/Collateral/NCP4201-D.PDF
In fact, if there is a capacitor between the enable pin and ground, then this would suggest that the enable is configured like a simple RC power-on reset.
V+ --- R --+--> Enable
          --- C
          _|_
« Last Edit: December 01, 2019, 11:16:32 pm by fzabkar »
Offline fzabkar
« Reply #29 on: November 30, 2019, 06:46:45 am »
Just for completeness, could you identify the markings of these 5 chips on the back of the PCB?
U5N1 is associated with L6B1 on the top side, so it must be a stepdown buck regulator.
    U1P1 DFN-10
    Q1P2 SOT23-3
    U5N1 SOT23-5
    Q6R2 SOT23-3
    U6U1 SOIC-8 audio amp ???
« Last Edit: November 30, 2019, 09:06:54 pm by fzabkar »
Offline fzabkar
« Reply #30 on: November 30, 2019, 09:17:45 pm »
These would be my power supply test points:
Offline fzabkar
« Reply #31 on: November 30, 2019, 09:20:35 pm »
More test points ...
Offline LiftedTrace
« Reply #32 on: December 01, 2019, 06:25:17 pm »
I really appreciate the time your taking to help me figure this out. Its a learning experience for me. I think I took care of the strange 3.3V output with the flaky enable. I replaced a cap and a resistor that were connected to the enable of U4C2. I cannot believe how challenging it is to replace these little buggers. Now that this enable has a good voltage to it, the 3.3v is working well. That being said, here is a list of all the test points you were asking for in them pics.
The ones that state "only after power on" go right back to zero after the unit shuts down.
TP4D1 = 3.29
TP4D2 = 5
TP4D4 = 1.83
TP4D5 = 1.135
TP4E1 = 1.11 (Only after power on)
TP4F1 = 1.81 (Only after power on)
TP4F2 = 1.83
TP5F1 = 0 (Even after power on)
TP5D1 = .6 (Only after power on)
TP5D3 (v_fuse) = 0
TP6F1 = 0 (Even after power on)
TP8B1 = 12
TP9D1 = .72 (Only after power on)
TP9D2 = 0 (Even after power on)
TP9F1 = 0 (Even after power on)
RT3F1 = 5
RT6B1/2 = Both 5V
L6B1 (Vout) = 12V
C9C5 (Vout) = 12V
U5D2 (pin 2) = 3.29
C5D4 = 1.84 (Only after power on)
U3D6 (Pin 5) = 1.83
The Chips on the back - Identification
U1P1   1206            Q1P2    KFD                  U5N2    C08F                                  Q6R2       KFD                         U6U1     8104SY1
            87K                           829                  (C has a line over it)                                       829                                     1814
           ADRG                                                 (08F have lines under them)        28053010
I am not sure. I know the data sheets for NCP4200/NCP42001 do not have the same number of pins, but they list the enable pins as pin 6.
The pin that is connected to the three chips, U9D2, U9E1, U9E2, is 28. Pin 28 on UC92 is connected to pin 3 on all three of them chips thru a resistor.
UC92 (Pin 28) -----------|-----(R)------U9D2 (pin 3)
                                        |-----(R) -----U9E1 (Pin 3)
                                        |-----(R)-----U9E2 (Pin 3)
If NCP4205 is similar, then it looks like the enables are all tied together to the bigger chips PWM(one of them) outputs, or the SW(one of them) output. Thats assuming they are similar enough where the PWM and SW are on the same sides.
Also, Pin 2 on U9D2 is connected to pin 27 of UC92.
So one thing I noticed when checking these test points is two of them were low when it powered up.
TP5D1 = .6 (Only after power on)  It should be 3.3v
TP9D1 = .72 (Only after power on) Not sure what this should be.
TP9D1 seems to be coming from the power supply in the lower right corner (U9F1). This seems to start up a bit but I dont know what it should be at. The test point is labeled MEMIO, so maybe it should be this low?
EDIT 1:
Forgive the hackery and ugliness of my skills. This: https://www.dropbox.com/s/ilu2rzqa8l6ucx5/XBOX%20Back.jpg?dl=0
is a photo of the back of the board. I seen this on the other xbox I had, the way the caps look. Like one side is missing the solder covered connection. Located on the left side in section "S" and "T" and "U".
"U" seems to be missing a Cap all together, and the one that is present seems to be missing its right solder connection. I remember this from the other board. I wonder how much of this is from water damage and how much is how it was from the factory.
The section in U1 also has some ugly looking caps, and when I tried to touch up the test points in that area, the board masking peeled off.
I wonder if there are traces inside the board that have eroded from the water damage. Is that even possible?
« Last Edit: December 01, 2019, 10:32:11 pm by LiftedTrace »
Offline fzabkar
« Reply #33 on: December 01, 2019, 10:32:44 pm »
I would think that MEMIO is the supply rail for the SDRAM chips, in which case it should be 1.5V (according to the data).
I would also measure the resistances between ground and each of the suspect test points.
ISTM that the SoC (U4D2) is powered from the primary standby supplies (V_3P3STBY, 1P8STBY, 1P1STBY). When it senses the power-on switch, it enables several other supplies, and these in turn enable the supplies for the SDRAM, CPU, GPU, and NorthBridge. I suspect that one of these supplies, or its load, has a problem, and that this problem causes the power-up sequence to terminate.
I would concentrate on those supplies that never come up to spec, even briefly (the last 7 in the list). Check their inputs, outputs, enables, and load resistances.
TP4D2 = 5P0            5
RT6B1/2 = rear USB     Both 5V
RT3F1 = front USB      5
L6B1 =                 12V
C9C5 =                 12V
TP8B1 = V_12P0         12
TP4F2 = V_BAT          1.83
TP4D1 = V_3P3STBY      3.29
TP4D4 = 1P8STBY        1.83
TP4D5 = 1P1STBY        1.135
U5D2 (pin 2) =         3.29
U3D6 (Pin 5) =         1.83
TP4E1 = SB1P1          1.11 (Only after power on)
TP4F1 = SB1P8          1.81 (Only after power on)
C5D4 = V_SOC1P8        1.84 (Only after power on)
TP5D1 = V_3P3          0.6 (Only after power on)      should be 3.3V (from U5D4 ?)
TP9D1 = MEMIO          0.72 (Only after power on)     should be 1.5V from TPS51916 et al
TP5D3 = V_FUSE         0                              from pin 5 of U5D3 LDO reg (AP2127)
TP5F1 = SOCPHY         0 (Even after power on)        from U5F5 switcher
TP9D2 = GFXCORE        0 (Even after power on)        from NCP4205 switcher et al
TP9F1 = CPUCORE        0 (Even after power on)        from NCP4205 switcher et al
TP6F1 = NBCORE         0 (Even after power on)        from TPS53819A switcher et al
« Last Edit: December 02, 2019, 07:43:48 am by fzabkar »
Offline fzabkar
« Reply #34 on: December 01, 2019, 11:21:23 pm »
I just reread one of your earlier posts and I'm sorry for my misleading reply. Of course the NCP4205 chip enables each of U9D2, U9E1, and U9E2. Those are the MOSFET gate drivers for the CPUCORE.
Doh! (slaps forehead)
Offline LiftedTrace
« Reply #35 on: December 02, 2019, 12:23:37 am »
Ok, So the output doesn't even hiccup on power up. The Shutdown control pin 3 i see a tiny spike when power on. I cannot track down where that pin 3 is connected. Its resistance to ground is 10K. I am suspecting its not getting enough to turn on. I could supply it with a small amount, but I am reluctant to, not knowing what it needs or where its going, so I am going to not do that. There are two diodes right next to it. (D5D2), the cathode goes to 3.3V after power on, the anode goes to .06. If I am not mistaken, should this not be around .7?
The input has a steady 3.3V and the output has nothing. I probed the other pins and found no other voltages present before or after power on. I cannot locate the datasheet on this chip either so I dont really know what pin does what.
This is coming from the three groups of mosfets that are not coming up. The chip that controls them getting its enable from NCP4205.
Ok, so I may be getting closer to something.
TP9D2 = GFXCORE  & TP9F1 = CPUCORE seem to be tied together. I noticed something strange though.
When I measure the resistance between TP9D2 = GFXCORE and the output of Q9D3(larger mosfet by large first coil), I get .3_Ohms.
When I measure the resistance between TP9F1 = CPUCORE and the output of Q9E3(larger mosfet by large last coil), I get .3_Ohms.
When I measure the resistance between TP9D2 = GFXCORE  & TP9F1 = CPUCORE  I get 10.4_Ohms.
So I started measuring the resistance between each of the larger mosfets.
1-2 = .3
2-3 = 10.4
1-3 = 10.4
1-G = 3.6
2-G = 3.4
3-G = 7.8
I find it strange these are not all the same which makes me think the issue may be on this power supply.
Maybe its fine? I do see a slight gap between the two top coils and the bottom coil. Maybe I am measuring the resistance thru the APU from the GFXCore and the CPUcore
The Vdd goes to 12v on power up. The enable and output gets nothing on power up.
Input is seeing 5V, Output spikes on power up, Enable Spikes a small amount on power up.
After measuring all of these, the only one that seem odd to me is the one by the diodes (U5D3).
Would it be normal for the voltage before the diode to be 3.3, and after be .03-.06?
Offline fzabkar
« Reply #36 on: December 02, 2019, 12:56:39 am »
ISTM that MOSFETS Q9D3 and Q9E1 supply the GPU core, while MOSFET Q9E3 supplies the CPU core. In fact you can see "CPUCORE" adjacent to capacitor C8E3, and "GFXCORE" between C8D1 and C8D2.
The resistance that you are measuring "between the two cores" is actually the sum of the resistances from CPUCORE to Ground, and from Ground to GFXCORE, ie 7.8 + 3.5 = 11.3 ohms.
Offline fzabkar
« Reply #37 on: December 02, 2019, 01:06:50 am »
I don't understand what you mean by "before and "after". The forward voltage drop would be limited to around 0.6V, while the reverse voltage rating could be 20V or more. A Schottky diode would have a lower Vf than a regular silicon rectifier.
Offline LiftedTrace
« Reply #38 on: December 02, 2019, 01:37:26 am »
My apologies. What I meant by "before" was the reading at the cathode and "after" was the reading at the anode.
Would a schottky diode have a forward voltage drop under .1v?
Maybe the only was I can check is to remove it and check out of circuit?
I see that now. By the way, what does "ISTM" mean?
https://www.diodes.com/assets/Datasheets/ds30308.pdf I believe is the schottky (D5D1 & D5D2). This lists the forward voltage as .3 ish.
Am i on the right track thinking this should be higher than .03-.06?
Offline fzabkar
« Reply #39 on: December 02, 2019, 01:51:55 am »
ISTM - it seems to me
A forward voltage drop of 0.1V is quite possible for a Schottky diode if the current is very low.
FWIW, I checked the V_EFUSE references in the Xbox 360 circuits. In that particular design the CPU generates a VREG_EFUSE_EN signal which enables an LDO regulator. This regulator generates a V_EFUSE supply from the V_5P0 supply, and V_EFUSE then powers one section of the CPU's internal logic. I have no idea what V_EFUSE does.
The V_3P3 supply in the Xbox 360 is generated by an LDO regulator, and this regulator is controlled via a VREG_3P3_EN signal from the SouthBridge.
Did you check the MEMIO regulator? Its output should be 1.5V.
« Last Edit: December 02, 2019, 02:16:55 am by fzabkar »
Offline LiftedTrace
« Reply #40 on: December 02, 2019, 02:08:28 am »
At this point, it seems I have quite a few power supplies not turning on because they are lacking their enables for some reason. Either they have no enable at all, or the enable never stays on. Other than the really low voltage on the schottky, I can not imagine what it might be. I could take that off and measure it just to see I suppose, but with a reverse break down voltage of 30v, I find it hard to believe this is the problem seen as its only seeing 3-4V.
I am trying to stay away from opening my xbox up, but I am thinking I may need a working one as a reference.....unless you may have any other options to check?
EDIT:
I did, it seems to be controlled by U9F1. Pin 13 (SW) spikes to about .7, same as MEMIO test point.
Pin 16&17 shoot up to 2.5 for a split second. I believe these are the enables of the chip. http://www.ti.com/lit/ds/symlink/tps51916.pdf (Page 17, State S0). Pin 16&17 are tied together, both are either Low (State S4/S5) or High (State S0).
So this chip too is not getting its enable held high.
Something else is triggering this whole thing to shut back down.
« Last Edit: December 02, 2019, 02:22:01 am by LiftedTrace »
Offline fzabkar
« Reply #41 on: December 02, 2019, 02:18:14 am »
MEMIO regulator?
You could check the voltages on U5D4.
Here is my guess:
    pin #1 - enable from southbridge
    pin #2 - ground or 5V input
    pin #3 - 5V input or ground
    pin #4 - V_3P3 output
    pin #5 - not connected ?
    pin #6 - feedback divider
« Last Edit: December 02, 2019, 02:42:08 am by fzabkar »
Offline LiftedTrace
« Reply #42 on: December 02, 2019, 02:33:46 am »
Ok, well I looked a little deeper. The pins on the chip itself (16&17) are not connected, but a resistance check between them shows .3_ohms.
Right behind it, is the ugliness I was talking about in the high res image of the back of the board.
The fact that pin 17 is connected to this ugly looking cap makes me wonder.
Offline LiftedTrace
« Reply #43 on: December 02, 2019, 02:40:08 am »
Here is my guess:
    pin #2 - ground
    pin #3 - 5V input
Correct. This chip has 5V on it. The enable spikes up and back down, and Pins 4&6 seems to be connected in a feed back configuration. Pin 5 seems t0 be NC
Offline fzabkar
« Reply #44 on: December 02, 2019, 02:51:40 am »
It seems odd that you found and replaced one genuine shorted component, but now you have another problem. I'm wondering whether you introduced a second fault.
My other question is, can the CPU/GPU run without a heatsink? Does it throttle itself if it gets too hot?
Offline LiftedTrace
« Reply #45 on: December 02, 2019, 03:02:14 am »
It is very strange, I agree.
As for the heatsink issue, I would say no, it cannot be run without a heatsink, but its not even getting powered up to generate any heat.
When I press the power button, I go from 30ma to 40ma current draw and back down. It it is only powered up for 1 second top, maybe less.
The system shuts down almost instantly.
Offline fzabkar
« Reply #46 on: December 02, 2019, 03:04:05 am »
I think we are both going blind. Pins 16 and 17 of U9F1 are connected on the top side of the PCB.
Offline LiftedTrace
« Reply #47 on: December 02, 2019, 03:06:46 am »
hahahahah  :-DD I must be tired, lol.
I was mistaking pins 11&12 for 16&17 DOH!!!
Ok, then in that case, on the photo i uploaded, pin 12 is the one thats connected to that funky looking cap.
So 16&17 do still only get a short burst of voltage and turn off again. What troubles me is when I measured between 11&12, thinking they were 16&17, I did get .3 ohms.
Thats .3 ohms between pins 11&12. The data sheet lists them as V5IN and DRVL.
I dont think these guys should be measuring a short between them do you?
Unless they are connected internally? One being an input and another an output?
« Last Edit: December 02, 2019, 03:13:38 am by LiftedTrace »
Offline fzabkar
« Reply #48 on: December 02, 2019, 03:20:08 am »
They should not be connected, either externally or internally. Something is wrong. Is it possible that you shorted the two pins while you were testing?
Otherwise, it could be that Q9F1 and Q9F2 are damaged.
« Last Edit: December 02, 2019, 03:23:05 am by fzabkar »
Offline LiftedTrace
« Reply #49 on: December 02, 2019, 03:32:16 am »
Its very possible I shorted them testing. The pins are very close together and I do not have a microscope. Only a small eye loop.
Measuring across Q9F1/2 doesnt show a short though.
EDIT:
OK, I think pin 11&12 were shorted. one of the pin solder was mushed. I fixed it. Same result though.
Pin 12 has constant 5V. now. Pin 11 spikes to about 3.2 then off again, and 16&17 spike up and down.
So it seems this one may me working too, but not getting its enable to stay on.
« Last Edit: December 02, 2019, 03:49:14 am by LiftedTrace »
Offline fzabkar
« Reply #50 on: December 02, 2019, 04:32:37 am »
I'm stumped. Sorry. :-(
Offline LiftedTrace
« Reply #51 on: December 02, 2019, 04:42:14 am »
I guess that means it’s time to open my Xbox for comparison  :-BROKE
Offline fzabkar
« Reply #52 on: December 02, 2019, 04:49:08 am »
I'm just parking my rough notes here. Maybe someone will be able to fill in the missing info.
X861949-007, Microsoft XBOX ONE ASIC, I/O Controller Hub, southbridge:
X949211-001, AMD, CPU/GPU:
USB 2.0 filter (U3F2), markings KR + 82 (cursive, 82 = date code?), DFN-6, probably equivalent to ...
PESD5V0U5BF / PESD5V0U5BV, NXP, Ultra low capacitance bidirectional fivefold ESD protection array, 1.9pF, 5V reverse standoff, marking B2 / G7, SOT886 / SOT666:
https://assets.nexperia.com/documents/data-sheet/PESD5V0U5BF_PESD5V0U5BV.pdf
from Xbox One S teardown:
https://de.ifixit.com/Teardown/Xbox+One+S+Teardown/65572
RT8111HM, Realtek, Ethernet controller, single port, Gigabit LAN, PCI Express, QFN-32:
Similar chips with higher pin count?
https://www.recomb-omsk.ru/published/SC/html/scripts/doc/A01-RTL8111EVL-F(RTL8111E-VL-CG_Datasheet_1%201.pdf (RTL8111E, QFN-48)
bothhand.info/pdf/spec-8111b%28140%29.pdf (RTL8111B-GR, QFN-48)
Diodes Inc ?, Schottky rectifier, marking 5X, SOD123
NTMFS4C50NT3G / NTMFS4C50NT1G, ON Semiconductor, MOSFET N-CH, 30V, 46A, marking 4C50, SO8FL:
https://www.digikey.com/product-detail/en/on-semiconductor/NTMFS4C50NT3G/NTMFS4C50NT3G-ND/4848828
https://www.digikey.com/product-detail/en/on-semiconductor/NTMFS4C50NT1G/NTMFS4C50NT1G-ND/4848827
U7B2, marking PWD + yww, STMicroelectronics, BGA, EEPROM, HDMI EDID + CEC
U8B1, marking PXD + yww, STMicroelectronics, BGA, EEPROM, HDMI EDID + CEC
photo of U6U1, marking 8104SY1 + 1612 + 26082460  -> compared with 8104SY1 + 1814 + 28053010
https://www.elektroda.pl/rtvforum/topic3387811.html#gallery-4
U5F5, markings 3A + 5F + C02, DFN-10, step-down converter (3A + FF + Q3W markings in Xbox One teardown)
Parts ID:
https://cdn.ihs.com/www/blog/consoleunder.png
On my XBOX One S, the 8-pin IC U4D4 has the marking IAEBG. It is TSOT23-8 package.
"AEB" is the product code for part number MP2161GJ from MonolithicPower.
« Last Edit: December 02, 2019, 06:42:05 am by fzabkar »
Offline LiftedTrace
« Reply #53 on: December 06, 2019, 02:53:34 pm »
So I have a little more info but I don’t know what it means.
My gut tells me there is something wrong in the area of U5D2 and U5D3.
I took my Xbox apart for reference and what I found was strange at the two diodes labeled D5D1 & D5D2
D5D2, Ohms reading, positive on anode, negative on cathode = 300
D5D2, Ohms reading, negative  on anode, positive on cathode = 10kish
D5D1, Ohms reading, positive on anode, negative on cathode = 300
D5D1, Ohms reading, negative  on anode, positive on cathode = 10kish
These are for the good working Xbox.
What I get for the broken one is.
D5D2, Ohms reading, positive on anode, negative on cathode = 260
D5D2, Ohms reading, negative  on anode, positive on cathode = (Fuke 115 meter “flashes” OL)
Manually setting range I get a value around 2.5k
It seems to mess up the auto range (confusing)
Same result for D5D1
Do you know what would cause the meters auto detect to freak out and flash OL. It was not steady like a normal open, but flashed. I don’t know what means. Best I could guess is a cap somewhere was charging and discharging quickly?
Anyways, it’s not normal to the working box, so I think what ever is causing this issue and the low ohms readings on across these diodes might be a step in the right direction.
EDIT 1:
Well, I have managed to fix the thing. While waiting for a response here from my last post, I decided to go thru the back side of the board and replace the nasty looking caps, and wouldn't you know it, the thing booted up, lol.
I guess thats a lesson learned that something on the opposite side of the board can effect another area which seems totally unrelated.
But its up and working  :box:  :box: Feels good to fix it.  ^-^
« Last Edit: December 06, 2019, 07:45:31 pm by LiftedTrace »
Offline fzabkar
« Reply #54 on: December 08, 2019, 03:38:34 am »
Congratulations!
Offline ijaved
« Reply #55 on: December 10, 2019, 08:44:37 pm »
Wow very encouraging post. I have one dead xbox one s sitting with me which I have to fix. I will definitely use this post to get pointers.
Do you have picture of the back on which area the cap went bad?
Offline fzabkar
« Reply #56 on: December 11, 2019, 01:54:11 am »
ICBW, but I think the OP was referring to the capacitors in the GFXcore and CPUcore sections. I thought that the measured resistance of 3 ohms seemed on the low side, but then the GPU and CPU draw tens of amps when running, so I dismissed it. In any case it would be interesting to know how the capacitors measured out of circuit. It would also help to know the normal resistance of the GFXcore and CPUcore loads on a working board.
Offline LiftedTrace
« Reply #57 on: December 11, 2019, 03:53:56 am »
Yeah, so on page one there is one of the posts has a pic of the back of the board. I thought I posted a higher res pic but can’t find the link.
Basically, these are what I replaced.
C1R10 / 11
C1T1 / 2
C1U2
C1U1( Already gone on a known good working Xbox, left it missing)
C1U3 / 4
I also had a strange issue with the RC section for the 3.3v area.
I replaced
R6P16
C6P13
The board is laid out in a nice grid format to locate these components as stated in one of the earlier posts.
These are all on the bottom of the board where the water damage was.
As for the caps in the GFxcore and CPU core sections, the large cans, I never touched them. It was only the small ceramic caps on the bottom I replaced.
Sadly I was so excited to see it draw a few amps and stay on and jumped the gun and put it all back together and started the updates.
I wish I would have taken measurements from it when I had the caps and stuff off not causing issues to see what normal was. I wasn’t ready to start taking my known working one apart  :-DD
Also, being water damage, it seems to have completely eaten away the solder on the caps and the board leaving a ugly connection if any exists any more.
A few of them I had to scrape the nasty away and then scrape some of the trace cover away to expose good copper so I could solder to that. You might have to get creative depending on how corroded they might be.
You can remove one of the caps off the top of the board in that section for the 8 I replaced. They are all in parallel. Two on top and two on the bottom, except for that one that seems to be deliberately missing one on the bottom. I forget the value, but I found donors from a old laptop mother board power supply section.
The one I got of eBay had the same section messed up and they looked the same. Maybe the water pools up in that corner.
Also the one I got from eBay had such bad damage it was beyond my repair. When looking closely at the ram chips at just the right angle(and my tongue also at just the right angle) I was able to see water damage under the ram chips. It was at the point I called it quits and resold it on eBay. I don’t have the means to remove large chips like that.
Best of luck.
Anything I can do to help, just post.
Also, as a reference, the one I repaired, just beeped on startup.
I had no fan or anything. It did a three rising tone beep and immediately shut off.
My working Xbox was drawing only 9ma on standby where the broken was drawing around 40ma.
Hope this helps.
« Last Edit: December 11, 2019, 04:04:07 am by LiftedTrace »
Offline fzabkar
« Reply #58 on: December 11, 2019, 10:33:41 pm »
Would you mind filling in the missing voltages?
Also, if any of your ICs differ from the OP's, would you mind posting their markings so that we can identify them and update the BOM?
