I really appreciate the time your taking to help me figure this out. Its a learning experience for me. I think I took care of the strange 3.3V output with the flaky enable. I replaced a cap and a resistor that were connected to the enable of U4C2. I cannot believe how challenging it is to replace these little buggers. Now that this enable has a good voltage to it, the 3.3v is working well. That being said, here is a list of all the test points you were asking for in them pics.
The ones that state "only after power on" go right back to zero after the unit shuts down.
TP4D1 = 3.29
TP4D2 = 5
TP4D4 = 1.83
TP4D5 = 1.135
TP4E1 = 1.11 (Only after power on)
TP4F1 = 1.81 (Only after power on)
TP4F2 = 1.83
TP5F1 = 0 (Even after power on)
TP5D1 = .6 (Only after power on)
TP5D3 (v_fuse) = 0
TP6F1 = 0 (Even after power on)
TP8B1 = 12
TP9D1 = .72 (Only after power on)
TP9D2 = 0 (Even after power on)
TP9F1 = 0 (Even after power on)
RT3F1 = 5
RT6B1/2 = Both 5V
L6B1 (Vout) = 12V
C9C5 (Vout) = 12V
U5D2 (pin 2) = 3.29
C5D4 = 1.84 (Only after power on)
U3D6 (Pin 5) = 1.83
The Chips on the back - Identification
U1P1 1206 Q1P2 KFD U5N2 C08F Q6R2 KFD U6U1 8104SY1
87K 829 (C has a line over it) 829 1814
ADRG (08F have lines under them) 28053010
Is it possible that the NCP4205's enable output is actually an enable input? That is, is the NCP4205 also being controlled from some other chip?
I am not sure. I know the data sheets for NCP4200/NCP42001 do not have the same number of pins, but they list the enable pins as pin 6.
The pin that is connected to the three chips, U9D2, U9E1, U9E2, is 28. Pin 28 on UC92 is connected to pin 3 on all three of them chips thru a resistor.
UC92 (Pin 28) -----------|-----(R)------U9D2 (pin 3)
|-----(R) -----U9E1 (Pin 3)
|-----(R)-----U9E2 (Pin 3)
If NCP4205 is similar, then it looks like the enables are all tied together to the bigger chips PWM(one of them) outputs, or the SW(one of them) output. Thats assuming they are similar enough where the PWM and SW are on the same sides.
Also, Pin 2 on U9D2 is connected to pin 27 of UC92.
So one thing I noticed when checking these test points is two of them were low when it powered up.
TP5D1 = .6 (Only after power on) It should be 3.3v
TP9D1 = .72 (Only after power on) Not sure what this should be.
TP9D1 seems to be coming from the power supply in the lower right corner (U9F1). This seems to start up a bit but I dont know what it should be at. The test point is labeled MEMIO, so maybe it should be this low?
EDIT 1:
Forgive the hackery and ugliness of my skills. This:
https://www.dropbox.com/s/ilu2rzqa8l6ucx5/XBOX%20Back.jpg?dl=0is a photo of the back of the board. I seen this on the other xbox I had, the way the caps look. Like one side is missing the solder covered connection. Located on the left side in section "S" and "T" and "U".
"U" seems to be missing a Cap all together, and the one that is present seems to be missing its right solder connection. I remember this from the other board. I wonder how much of this is from water damage and how much is how it was from the factory.
The section in U1 also has some ugly looking caps, and when I tried to touch up the test points in that area, the board masking peeled off.
I wonder if there are traces inside the board that have eroded from the water damage. Is that even possible?
