So I have a little more info but I don’t know what it means.
My gut tells me there is something wrong in the area of U5D2 and U5D3.
I took my Xbox apart for reference and what I found was strange at the two diodes labeled D5D1 & D5D2
D5D2, Ohms reading, positive on anode, negative on cathode = 300
D5D2, Ohms reading, negative on anode, positive on cathode = 10kish
D5D1, Ohms reading, positive on anode, negative on cathode = 300
D5D1, Ohms reading, negative on anode, positive on cathode = 10kish
These are for the good working Xbox.
What I get for the broken one is.
D5D2, Ohms reading, positive on anode, negative on cathode = 260
D5D2, Ohms reading, negative on anode, positive on cathode = (Fuke 115 meter “flashes” OL)
Manually setting range I get a value around 2.5k
It seems to mess up the auto range (confusing)
Same result for D5D1
Do you know what would cause the meters auto detect to freak out and flash OL. It was not steady like a normal open, but flashed. I don’t know what means. Best I could guess is a cap somewhere was charging and discharging quickly?
Anyways, it’s not normal to the working box, so I think what ever is causing this issue and the low ohms readings on across these diodes might be a step in the right direction.
EDIT 1:
Well, I have managed to fix the thing. While waiting for a response here from my last post, I decided to go thru the back side of the board and replace the nasty looking caps, and wouldn't you know it, the thing booted up, lol.
I guess thats a lesson learned that something on the opposite side of the board can effect another area which seems totally unrelated.
But its up and working
Feels good to fix it.
