Hi. I am a noob, leraning to swim in the deep end. I am looking for some help in my adventure trying to repair an xbox one s I got off ebay. I got it more for the fun of trying to repair it more than getting it to work. It was listed as having water damage, so I did what the standard is when you get anything....."Dont turn it on.....take it apartt".
I found right away that someone else had already had a go at this thing. There was a connector that looked really bodged and the board was shorted internally at that point. I have no clue if it was caused from the previous owner or what, but I dug out some of the burn to the point I had no more short. When I plug the mother board in now, I get a few virtually no current draw for about 1-2 seconds, then a few hundred mA draw for about a half a second, then back ti virtually nothing. It seems like something is maybe trying to start, and then shutting down.
I find many many posts of people having similar issue, the only difference they have that I dont is a speaker beep letting them know the board is powering up and then back down. I could not find any info online that talked about what may be going on when there is no feed back at all, so I thought I would ask the smartest group I know.....this forum.
I dont know much of what to tell you other than what I know.
The board takes 12v, and probing around the board I find 12volts present on all most all the power supplies. Where its missing is what I believe to be the power supply for the APU. When I press the power button, I see a voltage spike to 1v, and then off. I checked the mosfets and they are working and not shorted. I assume they are working because I see a short voltage spike and then off, so I can only assume they are getting triggered and then shut down again....which then makes me assume what ever is driving them is also working the way its supposed to. They are definitely not shorted.
I also have 5v, 3.3, 1.8v, and I believe another present when power is plugged in.
The fact that the board makes no noise at all when the power button is pressed makes me thing there is something deeper wrong than I am able to repair. Other than a slight audible sound coming from the 5v power supply coil when you press the button, there is no user audible feedback like there should be.
Does anyone have any sort of experience on the basics of how these devices power up? Why there may be no beeps from the speaker, etc. Here is a pic of the front and back of the board.
Besides me possibly ....
.... I hope to learn alot from this adventure.
