Author Topic: Xbox One X Power Supply Issue  (Read 249 times)
Offline benscubaTopic starter
« on: December 14, 2024, 10:06:53 pm »
Hello,
I have a dead power supply from an Xbox One X, No output at all.
I'm not a electronic expert so i tried to open it carefully and test any voltage from caps to avoid dead short  :-/O
I've look all the component i found i burnt one.
I searched i foundhttps://www.eevblog.com/forum/repair/xbox-one-x-power-supply-repair/msg3028000/#msg3028000topic about the same faulty component but no reference about it to replace it.
Did someone have any clue of the remplacement i can get?
« Last Edit: December 14, 2024, 10:16:34 pm by benscuba »
Offline Per Hansson
Re: Xbox One X Power Supply Issue
« Reply #1 on: December 15, 2024, 11:04:17 am »
You can remove the common mode choke and just replace it with two jumper wires: that way you can test that the power supply works.
If it does either find a scrap power supply to steal the common mode choke from (be sure it is rated for at least as much current as is shown on the label of the PSU, 2.75A in your case).
Or buy a new one on Mouser / Digikey / Elfa / Whatever with a fitting footprint :)
https://www.digikey.se/en/products/filter/common-mode-chokes/839?s=N4IgjCBcpgnATAZiqAxlAZgQwDYGcBTAGhAHsoBtcRAFiRpBLEQDYAGNhpxAVh9gDsjavwTDmA%2BCwAcIALokADgBcoIAMrKATgEsAdgHMQAX1NA
