Author Topic: XGecu T48 stopped working - self check hangs  (Read 254 times)
Offline Mark KrassTopic starter
« on: December 18, 2024, 02:34:20 pm »
Hello guys,
My 2-years old XGecu T48 suddenly stopped working. I went to Tools->System Self check, run it (no chip/adapter installed) and it hangs forever in the middle of the way - see screenshots.
Updated firmware & Xgpro to latest 1.31 & 12.67 - no effect...
Please avise?
Offline MathWizard
Re: XGecu T48 stopped working - self check hangs
« Reply #1 on: December 18, 2024, 03:17:25 pm »
So does it always get stuck at the same point ? Does it complete uploaded the other firmware ? Maybe someone knows the order the self-check does stuff. If it was a programmed chip gone bad, I'd ask Xgecu if they would sell the programmed chip.
I just got a new T48, and a little bit of something, is rolling around inside it. So I should open it up now, and see if there's a reset button or anything.
I opened it up, and broke the warranty seal for nothing, whatever was loose, already fell out. I don't see any reset button, but there's a lot of chips and SOT-23 parts in there, and a big PSU section. If you're lucky, the problem isn't in any MCU/processor.
« Last Edit: December 18, 2024, 03:43:18 pm by MathWizard »
« Reply #2 on: December 18, 2024, 04:10:42 pm »
Yep, it gets stuck at the same point each time. Firmware update completes fine. So it looks like the problem not in central MCU but I don't have any idea how around 30-40% of the target's port buffers died with no reason. Last time when I used my T48 all went fine. My it be a power supply issue of these buffers?
Do you know how self check is performed in T48 and what buffer chips are?
Can Xgecu support stuff get any hand here?
« Reply #3 on: December 18, 2024, 04:53:20 pm »
Found the reason! Changed USB cable and self check went ok. No glue how it is associated. Hope it will help others who may encounter this problem.
 >:D
