I'm trying to restore this scope . made in China in the 90, sadly after high voltage caps puffed out, and i made a full recap one channel does not work. I have manage to find the damage part a amplifier? IC named SG012 IB but I can't find anything on the net about it, i'm sure it is the problems as if I replace it with the one from the other channel it works... (kinda... as the positioning is not working at full range) I'm looking for any advice. a equivalent a datasheet anything at all.
