I bought one which has some issues. The frequency is off by 10 kHz at the low end and 90 kHz at the high end. I suspect that it needs alignment as it appears to have been repaired. I've also encountered a birdie that suggests there is a squeg, an unstable spurious oscillation, somewhere.
The user manual provides the alignment information and I have plenty of test gear. However, I've never undertaken this level of radio diagnosis, so if someone has experience with the FRG-7 at component level I'd appreciate a chance to discuss the problems and what the spectrum should look like at various test points.
I'm using the spectrum analyzer feature of the Instek MDO-2000E series which has the major virtue of not putting my 8560A front end at risk from DC offsets as I don't yet have a DC block for it.
Have Fun!
Reg
Edit: I've determined that the 3rd LO range is too large. If I trim TC403 to set the LO at 3.445 with the dial at 0 it is at 2.35 at 1000. I can't see how to correct that except to put a large cap in series with the air variable. Comments? This unit has the fine tune cap which I have set at midrange when it's centered.
