Author Topic: Yaesu FT-991a head set jack problem  (Read 931 times)
Offline jhormillaTopic starter
« on: August 22, 2023, 12:56:48 am »
Hi all, I have a Yaesu FT-991A with a head set jack problem, when I plug in my head set it's intermittent, i tried another head set and the same thing, I can't find anyone that sells this jack part# P1091426, for the mean time I swapped the head set jack with the key jack since it's the same part number but I now can't use the key jack. I looked in Digikey, Mouser, Newark etc. Any information would be appreciated.
« Last Edit: August 22, 2023, 12:58:40 am by jhormilla »
Online xrunner
  • hp>Agilent>Keysight>???
Re: Yaesu FT-991a head set jack problem
« Reply #1 on: August 22, 2023, 12:59:13 am »
Did you call Yaesu for parts? They sell all the parts for the newer radios, I've used them many times and this part will not be expensive.
« Reply #2 on: August 22, 2023, 03:37:50 am »
Yes, thank you. I did email them just before I posted here.
« Reply #3 on: September 02, 2023, 09:47:32 pm »
Update
Contacted Yaesu and they replied with this.
P1091426          Replaced by P1091686                                                  NOT IN STOCK
P1091686          Replaced by P1091749 CONNECTOR:PJ30460              NOT IN STOCK
P1091749          CONNECTOR:HPJC30460-APB0AS003                         Currently in Stock
Ordered two parts because there is a limit of 2, the new part has 9 pins the old has 6, cut the three pins that had no matching thru hole pads to go through on the PCB and all is good. I hope these hold up. The parts were under $4 for both. HTH
The following users thanked this post: xrunner, coromonadalix
