There is a lot of solder resin on this board, so I am going to clean it off best I can with denatured alchohol and then dry it well before preceding.
I made a measurements after the first stage (Q2014 emitter), but it looks like there is no 9 volts powering the Q2031. Wondering if that is right on 146mhz on receive. It looks like any of the following signals could turn turn on the 9 volts .... BP, H1, H2, H3. What do these mean?
If the 146 mhz signal doesnt go thru Q2031, then does it go thru d2054 and d2031?
I really could use a good description of the functions and switching on this board.
Aside, It is extremely difficult to read the board layout much less find the probe position on the board itself.
